[postgis-tickets] [PostGIS] #3548: Slow queries with ST_DWithin and geography columns
trac at osgeo.org
Mon May 9 10:21:42 PDT 2016
Reporter: rdallasgray | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.1.x
Resolution: invalid | Keywords: ST_DWithin geography
Changes (by pramsey):
* status: new => closed
* resolution: => invalid
Comment:
Spherical calculations are just more expensive than planar ones, as you've
demonstrated.
Only thing I see about your query you might want to change is, rather than
building up a 200-vertex line and calling dwithin on that, build up 199
2-vertex segments, and do a join against that set. The index winnow much
better, since it won't be using a global bounding box for the whole line,
but instead 199 much smaller ones for the segments.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3548#comment:2>
