[postgis-tickets] r14892 - Fix compiler warning in ST_GeometricMedian
Daniel Baston
dbaston at gmail.com
Wed May 11 07:27:53 PDT 2016
Author: dbaston
Date: 2016-05-11 07:27:52 -0700 (Wed, 11 May 2016)
New Revision: 14892
trunk/postgis/lwgeom_functions_analytic.c
Modified: trunk/postgis/lwgeom_functions_analytic.c
--- trunk/postgis/lwgeom_functions_analytic.c 2016-05-11 14:18:53 UTC (rev 14891)
+++ trunk/postgis/lwgeom_functions_analytic.c 2016-05-11 14:27:52 UTC (rev 14892)
@@ -1155,7 +1155,8 @@
GSERIALIZED* result;
LWGEOM* input;
LWPOINT* lwresult;
- double tolerance;
+ static const double min_default_tolerance = 1e-8;
+ double tolerance = min_default_tolerance;
bool compute_tolerance_from_box;
bool fail_if_not_converged;
int max_iter;
@@ -1194,16 +1195,11 @@
/* Compute a default tolerance based on the smallest dimension
* of the geometry's bounding box.
- static const double min_default_tolerance = 1e-8;
static const double tolerance_coefficient = 1e-6;
const GBOX* box = lwgeom_get_bbox(input);
- if (!box)
+ if (box)
- tolerance = min_default_tolerance;
- else
double min_dim = FP_MIN(box->xmax - box->xmin, box->ymax - box->ymin);
if (lwgeom_has_z(input))
min_dim = FP_MIN(min_dim, box->zmax - box->zmin);
