[postgis-tickets] [PostGIS] #3513: topology tests failing for PostgreSQL 9.6
trac at osgeo.org
Wed May 11 07:36:35 PDT 2016
Reporter: robe | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.3.0
Component: topology | Version: trunk
Resolution: fixed | Keywords:
Comment (by robe):
Okay I readded it 9.6 and made it first to run and fail the whole job if
it fails. Manually running it now. I'll reopen if it still fails.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3513#comment:13>
