[postgis-tickets] [PostGIS] #3540: Enable https for winnie/debbie
trac at osgeo.org
Wed May 11 09:35:13 PDT 2016
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: Management 2.0
Component: buildbots | Version: 2.2.x
Resolution: | Keywords:
Comment (by strk):
I've enabled HTTPS for debbie, using letsencrypt (but did not prepare any
provision for renewing the certs, so will need to check it again when that
happens).
For winnie, it would be easy if "winnie.postgis.net" pointed to debbie's
IP, so I could use it as a proxy for the real winnie. Is that possible ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3540#comment:1>
