[postgis-tickets] [PostGIS] #3540: Enable https for winnie/debbie
PostGIS trac at osgeo.org
Thu May 12 01:09:01 PDT 2016
  Reporter:  strk       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  medium     |  Milestone:  Management 2.0
 Component:  buildbots  |    Version:  2.2.x
Resolution:             |   Keywords:
Comment (by strk):
 There, winnie proxied by debbie (certified by letsencrypt):
   https://debbie.postgis.net:444
 The proxy will use https to connect to winnie, so encryption chain is not
 broken.
 Only, debbie will not check winnie's certificate for being trusted (I
 guess we could tech debbie to trust winnie certificate but I wouldn't
 trust a proprietary server myself so won't teach debbie to do that :)
 So, if you can keep that 1501 port on we can switch all winnie links to
 debbie:444.
 Actually, I'm doing that now for trac.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3540#comment:7>
