[postgis-tickets] [PostGIS] #3550: postgis crashes postgresql backend
trac at osgeo.org
Thu May 12 08:17:05 PDT 2016
Reporter: vvk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Comment (by pramsey):
This is not going to be debuggable then, if the only table that causes the
problem (intermittently at that) is on your machine. Presumably if I took
a copy of your table I wouldn't be able replicate since copies aren't
showing the problem at all?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3550#comment:3>
