[postgis-tickets] [PostGIS] #3552: Get rid of deprecated function calls in reverse_geocode function
PostGIS trac at osgeo.org
Thu May 12 11:53:11 PDT 2016
 Reporter:  robe            |      Owner:  robe
     Type:  defect          |     Status:  new
 Priority:  high            |  Milestone:  PostGIS 2.2.3
Component:  tiger geocoder  |    Version:  2.2.x
 Keywords:                  |
 As noted by pnorman is his cost analysis and others on IRC, using
 deprecated function calls kills performance big time.
 Time to expunge those from tiger geocoder which I had left in because
 well I needed to support older  PostGIS versions with newer tiger
 extensions for clients that couldn't upgrade.  No more of that for 2.2+.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3552>
