[postgis-tickets] r14899 - references #3552 get rid of depecated calls for PostGIS 2.3
Regina Obe
lr at pcorp.us
Thu May 12 12:05:45 PDT 2016
Author: robe
Date: 2016-05-12 12:05:45 -0700 (Thu, 12 May 2016)
New Revision: 14899
trunk/extras/tiger_geocoder/geocode/reverse_geocode.sql
Modified: trunk/extras/tiger_geocoder/geocode/reverse_geocode.sql
--- trunk/extras/tiger_geocoder/geocode/reverse_geocode.sql 2016-05-12 18:58:28 UTC (rev 14898)
+++ trunk/extras/tiger_geocoder/geocode/reverse_geocode.sql 2016-05-12 19:05:45 UTC (rev 14899)
@@ -127,7 +127,7 @@
FROM
(SELECT e.tlid, e.the_geom As line, n.fullname, COALESCE(n.prequalabr || '' '','''') || n.name AS streetname, n.predirabrv, COALESCE(suftypabrv, pretypabrv) As streettypeabbrev,
n.sufdirabrv, e.zip, e.side, e.fromhn, e.tohn , e.center_pt,
- ST_Distance_Sphere(ST_SetSRID(e.center_pt,4326),ST_SetSRID(ref_geom,4326)) As dist
+ ST_DistanceSphere(ST_SetSRID(e.center_pt,4326),ST_SetSRID(ref_geom,4326)) As dist
FROM ea AS e
LEFT JOIN (SELECT featnames.* FROM featnames
WHERE featnames.statefp = ' || quote_literal(var_state) ||' ) AS n ON (n.statefp = e.statefp AND n.tlid = e.tlid)
