[postgis-tickets] [PostGIS] #3553: SVN buildbot failures
trac at osgeo.org
Thu May 12 16:52:04 PDT 2016
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: Management 2.0
Component: buildbots | Version: 2.2.x
Keywords: |
Been getting errors on both Debbie and Winnie when connecting to SVN for
past couple of runs.
Caused by: org.tmatesoft.svn.core.SVNCancelException: svn: E200015:
E200015: ISVNAuthentication provider did not provide credentials; HTTP
authorization cancelled.
svn: E200015: ISVNAuthentication provider did not provide credentials;
HTTP authorization cancelled.
at
org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:60)
at
org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:51)
at
org.tmatesoft.svn.core.internal.io.dav.DAVUtil.findStartingProperties(DAVUtil.java:133)
at
org.tmatesoft.svn.core.internal.io.dav.DAVUtil.getBaselineProperties(DAVUtil.java:242)
at
org.tmatesoft.svn.core.internal.io.dav.DAVUtil.getBaselineInfo(DAVUtil.java:200)
at
org.tmatesoft.svn.core.internal.io.dav.DAVRepository.logImpl(DAVRepository.java:1021)
at
org.tmatesoft.svn.core.io.SVNRepository.log(SVNRepository.java:1038)
at
org.tmatesoft.svn.core.internal.wc2.remote.SvnRemoteLog.run(SvnRemoteLog.java:181)
at
org.tmatesoft.svn.core.internal.wc2.remote.SvnRemoteLog.run(SvnRemoteLog.java:35)
at
org.tmatesoft.svn.core.internal.wc2.SvnOperationRunner.run(SvnOperationRunner.java:21)
at
org.tmatesoft.svn.core.wc2.SvnOperationFactory.run(SvnOperationFactory.java:1235)
at
org.tmatesoft.svn.core.wc2.SvnOperation.run(SvnOperation.java:294)
at
org.tmatesoft.svn.core.wc.SVNLogClient.doLog(SVNLogClient.java:968)
at
org.tmatesoft.svn.core.wc.SVNLogClient.doLog(SVNLogClient.java:873)
at
hudson.scm.SubversionChangeLogBuilder.buildModule(SubversionChangeLogBuilder.java:187)
... 12 more
at
org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:723)
at
org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:398)
at
org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:386)
at
org.tmatesoft.svn.core.internal.io.dav.DAVConnection.performHttpRequest(DAVConnection.java:863)
at
org.tmatesoft.svn.core.internal.io.dav.DAVConnection.doPropfind(DAVConnection.java:151)
at
org.tmatesoft.svn.core.internal.io.dav.DAVUtil.getProperties(DAVUtil.java:70)
at
org.tmatesoft.svn.core.internal.io.dav.DAVUtil.getResourceProperties(DAVUtil.java:76)
at
org.tmatesoft.svn.core.internal.io.dav.DAVUtil.getStartingProperties(DAVUtil.java:100)
at
org.tmatesoft.svn.core.internal.io.dav.DAVUtil.findStartingProperties(DAVUtil.java:122)
problem I think is intermittent
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3553>
