[postgis-tickets] [PostGIS] #3550: postgis crashes postgresql backend
trac at osgeo.org
Thu May 12 21:56:21 PDT 2016
Reporter: vvk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Comment (by vvk):
>Presumably if I took a copy of your table I wouldn't be able replicate
since copies aren't showing the problem at all?
Original table also not crashing at every VACUUM ANALYZE, it only happens
several times per week.
> Did you rebuild PostGIS against 9.4 ?
Yes, I've rebuilt with 9.4 in order to add debug symbols.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3550#comment:5>
