[postgis-tickets] [PostGIS] #3555: Parallelization of PostGIS raster ST_Union aggregate
PostGIS trac at osgeo.org
Sat May 14 19:35:59 PDT 2016
 Reporter:  robe         |      Owner:  dustymugs
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS Future
Component:  raster       |    Version:  trunk
 Keywords:               |
 I experimented with this and sadly I think this is a no go for PostgreSQL
 9.6, though I'm keeping ourt hope for PostgreSQL 9.7.
 The reason I think it's a no go (unless we revise postgis raster ST_Union
 to use similar approach to ST_MemUnion (which might result in more loss
 than gain) is because I don't think the PostgresQL parallel aggregate
 infrastructure can support aggregates that use state transitions.
 Reason I thin that is that function like string_agg, array_agg don't
 support parallelization in 9.6
 http://www.hagander.net/talks/PostgreSQL_9.6.pdf#38
 I'm guessing its because they use that internal state transition stuff
 that we employ with our raster aggregates.
 I'll try to still experiment with a couple of approaches before I give up
 on 9.6 parallelization for raster.
 The ST_MapAlgebra functions look like good candidates for parallelization,
 so I'll add that aas a separate ticket, as I think that one would be
 easier to swing.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3555>
