[postgis-tickets] r14907 - Function costs for geometry functions based on query stats (Paul Norman)
Regina Obe lr at pcorp.us
Mon May 16 00:14:28 PDT 2016
Author: robe
Date: 2016-05-16 00:14:27 -0700 (Mon, 16 May 2016)
New Revision: 14907
   trunk/NEWS
   trunk/postgis/postgis.sql.in
closes #3557
Modified: trunk/NEWS
--- trunk/NEWS	2016-05-16 05:15:54 UTC (rev 14906)
+++ trunk/NEWS	2016-05-16 07:14:27 UTC (rev 14907)
@@ -24,6 +24,7 @@
   - #3465, ST_ClusterKMeans (Paul Ramsey)
   - #3469, ST_MakeLine with MULTIPOINTs (Paul Norman)
   - #3549, Support PgSQL 9.6 parallel query mode, as far as possible
+  - #3557, Geometry function costs based on query stats (Paul Norman)
 PostGIS 2.2.2
 2016/03/22
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in	2016-05-16 05:15:54 UTC (rev 14906)
+++ trunk/postgis/postgis.sql.in	2016-05-16 07:14:27 UTC (rev 14907)
@@ -63,7 +63,8 @@
       RAISE DEBUG '% signature was deprecated in %. Please use %', oldname, version, newname;
     END IF;
 END;
-$$ LANGUAGE 'plpgsql' IMMUTABLE STRICT;
+$$ LANGUAGE 'plpgsql' IMMUTABLE STRICT
+	COST 100;
 --  SPHEROID TYPE
@@ -1087,7 +1088,8 @@
 CREATE OR REPLACE FUNCTION ST_MemSize(geometry)
 	RETURNS int4
 	AS 'MODULE_PATHNAME', 'LWGEOM_mem_size'
-	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
+	LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
+	COST 5;
 -- Availability: 1.2.2
 -- Deprecation in 2.2.0
@@ -1102,13 +1104,15 @@
 CREATE OR REPLACE FUNCTION ST_summary(geometry)
 	RETURNS text
 	AS 'MODULE_PATHNAME', 'LWGEOM_summary'
+	COST 25;
 CREATE OR REPLACE FUNCTION ST_Npoints(geometry)
 	RETURNS int4
 	AS 'MODULE_PATHNAME', 'LWGEOM_npoints'
+	COST 10;
 CREATE OR REPLACE FUNCTION ST_nrings(geometry)
@@ -1123,26 +1127,29 @@
 CREATE OR REPLACE FUNCTION ST_3DLength(geometry)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME', 'LWGEOM_length_linestring'
+	COST 20;
 CREATE OR REPLACE FUNCTION ST_Length2d(geometry)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME', 'LWGEOM_length2d_linestring'
+	COST 10;
 -- PostGIS equivalent function: length2d(geometry)
 CREATE OR REPLACE FUNCTION ST_Length(geometry)
 	RETURNS FLOAT8
+	COST 10;
 -- Availability in 2.2.0
 CREATE OR REPLACE FUNCTION ST_LengthSpheroid(geometry, spheroid)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME','LWGEOM_length_ellipsoid_linestring'
-	COST 100;
+	COST 500;
 -- this is a fake (for back-compatibility)
 -- uses 3d if 3d is available, 2d otherwise
@@ -1171,7 +1178,7 @@
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME','LWGEOM_length2d_ellipsoid'
-	COST 100;
+	COST 500;
@@ -1186,39 +1193,44 @@
 CREATE OR REPLACE FUNCTION ST_3DPerimeter(geometry)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME', 'LWGEOM_perimeter_poly'
+	COST 10;
 CREATE OR REPLACE FUNCTION ST_perimeter2d(geometry)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME', 'LWGEOM_perimeter2d_poly'
+	COST 10;
 -- PostGIS equivalent function: perimeter2d(geometry)
 CREATE OR REPLACE FUNCTION ST_Perimeter(geometry)
 	RETURNS FLOAT8
+	COST 10;
 -- Deprecation in 1.3.4
 CREATE OR REPLACE FUNCTION ST_area2d(geometry)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME', 'LWGEOM_area_polygon'
+	COST 10;
 -- PostGIS equivalent function: area(geometry)
 CREATE OR REPLACE FUNCTION ST_Area(geometry)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME','area'
+	COST 10;
 -- Availability: 2.0.0
 CREATE OR REPLACE FUNCTION ST_DistanceSpheroid(geom1 geometry, geom2 geometry,spheroid)
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME','LWGEOM_distance_ellipsoid'
-	COST 100;
+	COST 200; --upped this
@@ -1236,7 +1248,7 @@
 	RETURNS float8
 	AS 'MODULE_PATHNAME', 'distance'
-	COST 100;
+	COST 25; --changed from 100 should be 1/5th to 1/10 spheroid
 -- Availability: 2.2.0
 CREATE OR REPLACE FUNCTION ST_PointInsideCircle(geometry,float8,float8,float8)
@@ -1267,7 +1279,8 @@
 CREATE OR REPLACE FUNCTION ST_Force2D(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_2d'
+	COST 5;
 -- Deprecation in 2.1.0
@@ -1282,7 +1295,8 @@
 CREATE OR REPLACE FUNCTION ST_Force3DZ(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_3dz'
+	COST 25;
@@ -1297,7 +1311,8 @@
 CREATE OR REPLACE FUNCTION ST_Force3D(geometry)
 	RETURNS geometry
+	COST 25;
@@ -1312,7 +1327,8 @@
 CREATE OR REPLACE FUNCTION ST_Force3DM(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_3dm'
+	COST 25;
@@ -1327,7 +1343,8 @@
 CREATE OR REPLACE FUNCTION ST_Force4D(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_4d'
+	COST 25;
@@ -1342,7 +1359,8 @@
 CREATE OR REPLACE FUNCTION ST_ForceCollection(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_collection'
+	COST 10;
@@ -1369,7 +1387,8 @@
 CREATE OR REPLACE FUNCTION ST_Multi(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_multi'
+	COST 10;
 CREATE OR REPLACE FUNCTION ST_ForceCurve(geometry)
@@ -1387,25 +1406,29 @@
 CREATE OR REPLACE FUNCTION ST_ForceSFS(geometry, version text)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_sfs'
+	COST 10;
 CREATE OR REPLACE FUNCTION ST_Expand(box3d,float8)
 	RETURNS box3d
 	AS 'MODULE_PATHNAME', 'BOX3D_expand'
+	COST 25;
 CREATE OR REPLACE FUNCTION ST_Expand(geometry,float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_expand'
+	COST 25;
 -- PostGIS equivalent function: envelope(geometry)
 CREATE OR REPLACE FUNCTION ST_Envelope(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_envelope'
+	COST 25;
 CREATE OR REPLACE FUNCTION ST_BoundingDiagonal(geom geometry, fits boolean DEFAULT false)
@@ -1417,37 +1440,43 @@
 CREATE OR REPLACE FUNCTION ST_Reverse(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_reverse'
+	COST 10;
 CREATE OR REPLACE FUNCTION ST_ForceRHR(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_force_clockwise_poly'
+	COST 15;
 -- Availability: 1.5.0
 CREATE OR REPLACE FUNCTION postgis_noop(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_noop'
-	LANGUAGE 'c' VOLATILE STRICT _PARALLEL;
+	LANGUAGE 'c' VOLATILE STRICT _PARALLEL
+	COST 10;
 -- Deprecation in 1.5.0
 CREATE OR REPLACE FUNCTION ST_zmflag(geometry)
 	RETURNS smallint
 	AS 'MODULE_PATHNAME', 'LWGEOM_zmflag'
+	COST 5;
 CREATE OR REPLACE FUNCTION ST_NDims(geometry)
 	RETURNS smallint
 	AS 'MODULE_PATHNAME', 'LWGEOM_ndims'
+	COST 5;
 CREATE OR REPLACE FUNCTION ST_AsEWKT(geometry)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asEWKT'
+	COST 750; --this looks suspicious, requires recheck
 CREATE OR REPLACE FUNCTION ST_AsTWKB(geom geometry, prec int4 default NULL, prec_z int4 default NULL, prec_m int4 default NULL, with_sizes boolean default NULL, with_boxes boolean default NULL)
@@ -1465,25 +1494,29 @@
 CREATE OR REPLACE FUNCTION ST_AsEWKB(geometry)
 	RETURNS BYTEA
 	AS 'MODULE_PATHNAME','WKBFromLWGEOM'
+	COST 10;
 CREATE OR REPLACE FUNCTION ST_AsHEXEWKB(geometry)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asHEXEWKB'
+	COST 25;
 CREATE OR REPLACE FUNCTION ST_AsHEXEWKB(geometry, text)
 	RETURNS TEXT
+	COST 25;
 CREATE OR REPLACE FUNCTION ST_AsEWKB(geometry,text)
 	RETURNS bytea
+	COST 10;
 CREATE OR REPLACE FUNCTION ST_AsLatLonText(geom geometry, tmpl text DEFAULT '')
@@ -1669,7 +1702,8 @@
 CREATE OR REPLACE FUNCTION ST_Affine(geometry,float8,float8,float8,float8,float8,float8,float8,float8,float8,float8,float8,float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_affine'
+	COST 25;
 CREATE OR REPLACE FUNCTION ST_Affine(geometry,float8,float8,float8,float8,float8,float8)
@@ -1765,7 +1799,8 @@
 CREATE OR REPLACE FUNCTION ST_Dump(geometry)
 	RETURNS SETOF geometry_dump
 	AS 'MODULE_PATHNAME', 'LWGEOM_dump'
-	LANGUAGE 'c' IMMUTABLE STRICT;
+	COST 100;
 CREATE OR REPLACE FUNCTION ST_DumpRings(geometry)
@@ -1876,7 +1911,8 @@
 CREATE OR REPLACE FUNCTION ST_DumpPoints(geometry)
 	AS 'MODULE_PATHNAME', 'LWGEOM_dumppoints'
+	COST 100;
@@ -2677,12 +2713,14 @@
 CREATE OR REPLACE FUNCTION ST_SetSRID(geometry,int4)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','LWGEOM_set_srid'
+	COST 10;
 CREATE OR REPLACE FUNCTION ST_SRID(geometry)
 	RETURNS int4
 	AS 'MODULE_PATHNAME','LWGEOM_get_srid'
+	COST 5;
 CREATE OR REPLACE FUNCTION postgis_transform_geometry(geometry,text,text,int)
 	RETURNS geometry
@@ -2693,7 +2731,8 @@
 CREATE OR REPLACE FUNCTION ST_Transform(geometry,integer)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','transform'
+	COST 100;
 -- Availability: 2.3.0
 CREATE OR REPLACE FUNCTION ST_Transform(geom geometry, to_proj text)
@@ -2927,17 +2966,20 @@
 CREATE OR REPLACE FUNCTION box2d(geometry)
 	RETURNS box2d
 	AS 'MODULE_PATHNAME','LWGEOM_to_BOX2D'
+	COST 10;
 CREATE OR REPLACE FUNCTION box3d(geometry)
 	RETURNS box3d
 	AS 'MODULE_PATHNAME','LWGEOM_to_BOX3D'
+	COST 10;
 CREATE OR REPLACE FUNCTION box(geometry)
 	RETURNS box
 	AS 'MODULE_PATHNAME','LWGEOM_to_BOX'
+	COST 10;
 CREATE OR REPLACE FUNCTION box2d(box3d)
 	RETURNS box2d
@@ -2957,7 +2999,8 @@
 CREATE OR REPLACE FUNCTION text(geometry)
 	RETURNS text
 	AS 'MODULE_PATHNAME','LWGEOM_to_text'
+	COST 25;
 -- this is kept for backward-compatibility
 -- Deprecation in 1.2.3
@@ -2989,7 +3032,8 @@
 CREATE OR REPLACE FUNCTION bytea(geometry)
 	RETURNS bytea
 	AS 'MODULE_PATHNAME','LWGEOM_to_bytea'
+	COST 10;
 -- 7.3+ explicit casting definitions
 CREATE CAST (geometry AS box2d) WITH FUNCTION box2d(geometry) AS IMPLICIT;
@@ -3018,39 +3062,45 @@
 CREATE OR REPLACE FUNCTION ST_Simplify(geometry, float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_simplify2d'
+	COST 50;
 CREATE OR REPLACE FUNCTION ST_Simplify(geometry, float8, boolean)
 	RETURNS geometry
+	COST 50; -- COST guessed from ST_Simplify(geometry, float8)
 CREATE OR REPLACE FUNCTION ST_SimplifyVW(geometry,  float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_SetEffectiveArea'
 CREATE OR REPLACE FUNCTION ST_SetEffectiveArea(geometry,  float8 default -1, integer default 1)
 	RETURNS geometry
 -- ST_SnapToGrid(input, xoff, yoff, xsize, ysize)
 CREATE OR REPLACE FUNCTION ST_SnapToGrid(geometry, float8, float8, float8, float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_snaptogrid'
+	COST 25;
 -- ST_SnapToGrid(input, xsize, ysize) # offsets=0
 CREATE OR REPLACE FUNCTION ST_SnapToGrid(geometry, float8, float8)
 	RETURNS geometry
 	AS 'SELECT ST_SnapToGrid($1, 0, 0, $2, $3)'
-	LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
+	LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL
+	COST 25;
 -- ST_SnapToGrid(input, size) # xsize=ysize=size, offsets=0
@@ -3064,13 +3114,15 @@
 CREATE OR REPLACE FUNCTION ST_SnapToGrid(geom1 geometry, geom2 geometry, float8, float8, float8, float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_snaptogrid_pointoff'
+	COST 25; -- COST from ST_SnapToGrid(input, xoff, yoff, xsize, ysize)
 CREATE OR REPLACE FUNCTION ST_Segmentize(geometry, float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'LWGEOM_segmentize2d'
+	COST 25;
 -- LRS
@@ -3180,21 +3232,21 @@
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','intersection'
-	COST 100;
+	COST 100; -- Guessed cost
 -- PostGIS equivalent function: buffer(geometry,float8)
 CREATE OR REPLACE FUNCTION ST_Buffer(geometry,float8)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','buffer'
-	COST 100;
+	COST 5000;
 -- Availability: 1.5.0 - requires GEOS-3.2 or higher
 CREATE OR REPLACE FUNCTION _ST_Buffer(geometry,float8,cstring)
 	RETURNS geometry
-	COST 100;
+	COST 5000;
 CREATE OR REPLACE FUNCTION ST_Buffer(geometry,float8,integer)
@@ -3230,21 +3282,21 @@
        RETURNS geometry
        AS 'MODULE_PATHNAME','ST_OffsetCurve'
-       COST 100;
 CREATE OR REPLACE FUNCTION ST_GeneratePoints(area geometry, npoints numeric)
        RETURNS geometry
        AS 'MODULE_PATHNAME','ST_GeneratePoints'
-       COST 400;
+       COST 400; -- Guessed cost
 -- PostGIS equivalent function: convexhull(geometry)
 CREATE OR REPLACE FUNCTION ST_ConvexHull(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','convexhull'
-	COST 100;
+	COST 250;
 -- Only accepts LINESTRING as parameters.
 -- Availability: 1.4.0
@@ -3252,7 +3304,7 @@
 	RETURNS integer
 	AS 'MODULE_PATHNAME', 'ST_LineCrossingDirection'
-	COST 100;
 CREATE OR REPLACE FUNCTION ST_LineCrossingDirection(geom1 geometry, geom2 geometry)
@@ -3266,7 +3318,7 @@
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','topologypreservesimplify'
-	COST 100;
+	COST 2000;
 -- Requires GEOS >= 3.1.0
@@ -3274,7 +3326,7 @@
 	RETURNS text
 	AS 'MODULE_PATHNAME', 'isvalidreason'
-	COST 100;
+	COST 1000;
 CREATE TYPE valid_detail AS (
@@ -3289,7 +3341,7 @@
 	RETURNS valid_detail
 	AS 'MODULE_PATHNAME', 'isvaliddetail'
-	COST 100;
+	COST 1000;
 -- Requires GEOS >= 3.3.0
@@ -3297,7 +3349,7 @@
-	COST 100;
+	COST 1000;
@@ -3316,8 +3368,7 @@
 CREATE OR REPLACE FUNCTION ST_IsValid(geometry, int4)
 	RETURNS boolean
 	AS 'SELECT (ST_isValidDetail($1, $2)).valid'
-	COST 100;
+	LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
 -- Requires GEOS >= 3.2.0
@@ -3326,7 +3377,7 @@
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME', 'hausdorffdistance'
-	COST 100;
@@ -3334,13 +3385,14 @@
 	RETURNS FLOAT8
 	AS 'MODULE_PATHNAME', 'hausdorffdistancedensify'
-	COST 100;
 -- PostGIS equivalent function: difference(geom1 geometry, geom2 geometry)
 CREATE OR REPLACE FUNCTION ST_Difference(geom1 geometry, geom2 geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME','difference'
+	COST 100; --guessed based on ST_Intersection
 -- PostGIS equivalent function: boundary(geometry)
 CREATE OR REPLACE FUNCTION ST_Boundary(geometry)
@@ -3390,7 +3442,7 @@
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'ST_RemoveRepeatedPoints'
-       COST 100;
+       COST 25;
 -- Requires GEOS >= 3.5.0
@@ -3398,7 +3450,7 @@
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_ClipByBox2d'
-	COST 50;
+	COST 50; -- Guessed cost
@@ -3406,7 +3458,7 @@
 	RETURNS setof geometry
 	AS 'MODULE_PATHNAME', 'ST_Subdivide'
-	COST 100;
@@ -3426,7 +3478,7 @@
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'ST_MakeValid'
-       COST 100;
+       COST 1000;
 -- ST_CleanGeometry(in geometry)
@@ -3447,7 +3499,7 @@
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'ST_CleanGeometry'
-       COST 100;
+       COST 1000;
 -- ST_Split
@@ -3467,7 +3519,7 @@
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'ST_Split'
-       COST 100;
 -- ST_SharedPaths
@@ -3490,7 +3542,7 @@
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'ST_SharedPaths'
-       COST 100;
 -- ST_Snap
@@ -3507,7 +3559,7 @@
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'ST_Snap'
-       COST 100;
 -- ST_RelateMatch
@@ -3524,7 +3576,7 @@
        RETURNS bool
        AS 'MODULE_PATHNAME', 'ST_RelateMatch'
-       COST 100;
 -- ST_Node
@@ -3543,7 +3595,7 @@
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'ST_Node'
-       COST 100;
 -- ST_DelaunayTriangles
@@ -3567,7 +3619,7 @@
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'ST_DelaunayTriangles'
-       COST 100;
+       COST 25000;
 -- ST_Voronoi
@@ -3597,7 +3649,7 @@
        RETURNS geometry
        AS 'MODULE_PATHNAME', 'ST_Voronoi'
        LANGUAGE 'c' IMMUTABLE _PARALLEL
-       COST 100;
+       COST 25000; -- Guessed cost
@@ -3879,7 +3931,7 @@
 	RETURNS boolean
 	AS 'MODULE_PATHNAME','touches'
-	COST 100;
 -- Inlines index magic
@@ -3893,7 +3945,7 @@
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'LWGEOM_dwithin'
-	COST 100;
 CREATE OR REPLACE FUNCTION ST_DWithin(geom1 geometry, geom2 geometry, float8)
@@ -3906,7 +3958,7 @@
 	RETURNS boolean
 	AS 'MODULE_PATHNAME','intersects'
-	COST 100;
@@ -3920,7 +3972,7 @@
 	RETURNS boolean
 	AS 'MODULE_PATHNAME','crosses'
-	COST 100;
@@ -3934,7 +3986,7 @@
 	RETURNS boolean
 	AS 'MODULE_PATHNAME','contains'
-	COST 100;
@@ -3948,7 +4000,7 @@
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'coveredby'
-	COST 100;
 CREATE OR REPLACE FUNCTION ST_CoveredBy(geom1 geometry, geom2 geometry)
@@ -3961,7 +4013,7 @@
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'covers'
-	COST 100;
@@ -3975,7 +4027,7 @@
 	RETURNS boolean
 	AS 'MODULE_PATHNAME','containsproperly'
-	COST 100;
@@ -3989,7 +4041,7 @@
 	RETURNS boolean
 	AS 'MODULE_PATHNAME','overlaps'
-	COST 100;
 -- PostGIS equivalent function: within(geom1 geometry, geom2 geometry)
 CREATE OR REPLACE FUNCTION _ST_Within(geom1 geometry, geom2 geometry)
@@ -4017,7 +4069,7 @@
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'isvalid'
-	COST 100;
+	COST 1000;
 CREATE OR REPLACE FUNCTION ST_MinimumClearance(geometry)
@@ -4035,7 +4087,8 @@
 CREATE OR REPLACE FUNCTION ST_Centroid(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'centroid'
+	COST 100;
@@ -4055,26 +4108,28 @@
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'pointonsurface'
-	COST 100;
+	COST 2500; --this looks suspicious, should not be this high
 -- PostGIS equivalent function: IsSimple(geometry)
 CREATE OR REPLACE FUNCTION ST_IsSimple(geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'issimple'
+	COST 25;
 CREATE OR REPLACE FUNCTION ST_IsCollection(geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'ST_IsCollection'
+	COST 5;
 CREATE OR REPLACE FUNCTION _ST_Equals(geom1 geometry, geom2 geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME','ST_Equals'
-	COST 100;
+	COST 100; --Guessed cost
 -- Availability: 1.2.1
 CREATE OR REPLACE FUNCTION ST_Equals(geom1 geometry, geom2 geometry)
@@ -4174,7 +4229,8 @@
 CREATE OR REPLACE FUNCTION ST_AsSVG(geom geometry,rel int4 DEFAULT 0,maxdecimaldigits int4 DEFAULT 15)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asSVG'
+	COST 1000;
 -- GML OUTPUT
@@ -4183,7 +4239,8 @@
 CREATE OR REPLACE FUNCTION _ST_AsGML(int4, geometry, int4, int4, text, text)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asGML'
-	LANGUAGE 'c' IMMUTABLE _PARALLEL;
+	LANGUAGE 'c' IMMUTABLE _PARALLEL
+	COST 2500;
 -- ST_AsGML(version, geom) / precision=15
 -- Availability: 1.3.2
@@ -4217,7 +4274,8 @@
 CREATE OR REPLACE FUNCTION _ST_AsKML(int4,geometry, int4, text)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asKML'
-	LANGUAGE 'c' IMMUTABLE;
+	COST 5000;
 -- Changed: 2.0.0 to use default args and allow named args
@@ -4245,7 +4303,8 @@
 CREATE OR REPLACE FUNCTION ST_AsGeoJson(geom geometry, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0)
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asGeoJson'
+	COST 1000;
 -- _ST_AsGeoJson(version, geom, precision, options)
 CREATE OR REPLACE FUNCTION _ST_AsGeoJson(int4, geometry, int4, int4)
@@ -4318,7 +4377,8 @@
 CREATE OR REPLACE FUNCTION ST_Dimension(geometry)
 	RETURNS int4
 	AS 'MODULE_PATHNAME', 'LWGEOM_dimension'
+	COST 10;
 -- PostGIS equivalent function: ExteriorRing(geometry)
 CREATE OR REPLACE FUNCTION ST_ExteriorRing(geometry)
@@ -4348,13 +4408,15 @@
 CREATE OR REPLACE FUNCTION GeometryType(geometry)
 	RETURNS text
 	AS 'MODULE_PATHNAME', 'LWGEOM_getTYPE'
+	COST 10; -- COST guessed from ST_GeometryType(geometry)
 -- Not quite equivalent to GeometryType
 CREATE OR REPLACE FUNCTION ST_GeometryType(geometry)
 	RETURNS text
 	AS 'MODULE_PATHNAME', 'geometry_geometrytype'
+	COST 10;
 -- PostGIS equivalent function: PointN(geometry,integer)
 CREATE OR REPLACE FUNCTION ST_PointN(geometry,integer)
@@ -4398,25 +4460,29 @@
 CREATE OR REPLACE FUNCTION ST_IsClosed(geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'LWGEOM_isclosed'
+	COST 10;
 -- PostGIS equivalent function: IsEmpty(geometry)
 CREATE OR REPLACE FUNCTION ST_IsEmpty(geometry)
 	RETURNS boolean
 	AS 'MODULE_PATHNAME', 'LWGEOM_isempty'
+	COST 10;
 CREATE OR REPLACE FUNCTION ST_AsBinary(geometry,text)
 	RETURNS bytea
 	AS 'MODULE_PATHNAME','LWGEOM_asBinary'
+	COST 10;
 -- PostGIS equivalent of old function: AsBinary(geometry)
 CREATE OR REPLACE FUNCTION ST_AsBinary(geometry)
 	RETURNS bytea
+	COST 10;
 -- PostGIS equivalent function: AsText(geometry)
 CREATE OR REPLACE FUNCTION ST_AsText(geometry)
@@ -4941,7 +5007,8 @@
 CREATE OR REPLACE FUNCTION ST_SwapOrdinates(geom geometry, ords cstring)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_SwapOrdinates'
+	COST 25; -- COST guessed from ST_FlipCoordinates(geometry)
 -- NOTE: same as ST_SwapOrdinates(geometry, 'xy')
 --       but slightly faster in that it doesn't need to parse ordinate
@@ -4949,7 +5016,8 @@
 CREATE OR REPLACE FUNCTION ST_FlipCoordinates(geometry)
 	RETURNS geometry
 	AS 'MODULE_PATHNAME', 'ST_FlipCoordinates'
+	COST 25;
 -- SFSQL 1.1
@@ -5340,7 +5408,8 @@
 CREATE OR REPLACE FUNCTION ST_CoordDim(Geometry geometry)
 	RETURNS smallint
+	COST 5;
 -- SQL-MM
