[postgis-tickets] [PostGIS] #3562: Revise regress test suite to support testing of parallelization
PostGIS trac at osgeo.org
Mon May 16 23:32:42 PDT 2016
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by robe):
 In theory it should be because the final worker has to merge all the
 results from slave workers.  So if the final has an ORDER BY, the results
 should be ordered.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3562#comment:2>
