[postgis-tickets] r14926 - Improve query performance in cb_getEdgeByFace
Sandro
strk at kbt.io
Tue May 31 03:07:55 PDT 2016
Author: strk
Date: 2016-05-31 03:07:55 -0700 (Tue, 31 May 2016)
New Revision: 14926
trunk/topology/postgis_topology.c
Avoids 1 output and 1 parse calls for hexwkb,
2 output and parse calls for integer arrays.
Was found reducing runtime from 16 seconds to 10 seconds for
adding a single polygon with a large shell and 129 holes
to an empty topology.
Modified: trunk/topology/postgis_topology.c
--- trunk/topology/postgis_topology.c 2016-05-31 07:58:21 UTC (rev 14925)
+++ trunk/topology/postgis_topology.c 2016-05-31 10:07:55 UTC (rev 14926)
@@ -14,6 +14,8 @@
#include "fmgr.h"
#include "utils/elog.h"
#include "utils/memutils.h" /* for TopMemoryContext */
+#include "utils/array.h" /* for ArrayType */
+#include "catalog/pg_type.h" /* for INT4OID */
#include "lib/stringinfo.h"
#include "access/xact.h" /* for RegisterXactCallback */
#include "funcapi.h" /* for FuncCallContext */
@@ -114,15 +116,13 @@
-/* Return lwalloc'ed hexwkb representation for a GBOX */
-static char *
-_box2d_to_hexwkb(const GBOX *bbox, int srid)
+/* Return an lwalloc'ed geometrical representation of the box */
+static LWGEOM *
+_box2d_to_lwgeom(const GBOX *bbox, int srid)
POINTARRAY *pa = ptarray_construct(0, 0, 2);
POINT4D p;
LWLINE *line;
- char *hex;
- size_t sz;
p.x = bbox->xmin;
p.y = bbox->ymin;
@@ -131,8 +131,18 @@
p.y = bbox->ymax;
ptarray_set_point4d(pa, 1, &p);
line = lwline_construct(srid, NULL, pa);
- hex = lwgeom_to_hexwkb( lwline_as_lwgeom(line), WKT_EXTENDED, &sz);
- lwline_free(line);
+ return lwline_as_lwgeom(line);
+/* Return lwalloc'ed hexwkb representation for a GBOX */
+static char *
+_box2d_to_hexwkb(const GBOX *bbox, int srid)
+ char *hex;
+ size_t sz;
+ LWGEOM *geom = _box2d_to_lwgeom(bbox, srid);
+ hex = lwgeom_to_hexwkb(geom, WKT_EXTENDED, &sz);
+ lwgeom_free(geom);
assert(hex[sz-1] == '\0');
return hex;
@@ -872,34 +882,47 @@
StringInfoData sqldata;
StringInfo sql = &sqldata;
int i;
- char *hexbox;
+ ArrayType *array_ids;
+ Datum *datum_ids;
+ Datum values[2];
+ Oid argtypes[2];
+ int nargs = 1;
+ GSERIALIZED *gser = NULL;
+ datum_ids = palloc(sizeof(Datum)*(*numelems));
+ for (i=0; i<*numelems; ++i) datum_ids[i] = Int32GetDatum(ids[i]);
+ array_ids = construct_array(datum_ids, *numelems, INT4OID, 4, true, 's');
initStringInfo(sql);
appendStringInfoString(sql, "SELECT ");
addEdgeFields(sql, fields, 0);
- appendStringInfo(sql, " FROM \"%s\".edge_data", topo->name);
- appendStringInfoString(sql, " WHERE ( left_face IN (");
- // add all identifiers here
- for (i=0; i<*numelems; ++i) {
- appendStringInfo(sql, "%s%" LWTFMT_ELEMID, (i?",":""), ids[i]);
- appendStringInfoString(sql, ") OR right_face IN (");
- appendStringInfoString(sql, ") )");
+ appendStringInfo(sql, " FROM \"%s\".edge_data"
+ " WHERE ( left_face = ANY($1) "
+ " OR right_face = ANY ($1) )",
+ topo->name);
+ values[0] = PointerGetDatum(array_ids);
+ argtypes[0] = INT4ARRAYOID;
if ( box )
- hexbox = _box2d_to_hexwkb(box, topo->srid);
- appendStringInfo(sql, " AND geom && '%s'::geometry", hexbox);
- lwfree(hexbox);
+ LWGEOM *g = _box2d_to_lwgeom(box, topo->srid);
+ gser = geometry_serialize(g);
+ lwgeom_free(g);
+ appendStringInfo(sql, " AND geom && $2");
+ values[1] = PointerGetDatum(gser);
+ argtypes[1] = topo->geometryOID;
+ ++nargs;
POSTGIS_DEBUGF(1, "cb_getEdgeByFace query: %s", sql->data);
POSTGIS_DEBUGF(1, "data_changed is %d", topo->be_data->data_changed);
- spi_result = SPI_execute(sql->data, !topo->be_data->data_changed, 0);
+ spi_result = SPI_execute_with_args(sql->data, nargs, argtypes, values, NULL,
+ !topo->be_data->data_changed, 0);
+ pfree(array_ids); /* not needed anymore */
+ if ( gser ) pfree(gser); /* not needed anymore */
MemoryContextSwitchTo( oldcontext ); /* switch back */
if ( spi_result != SPI_OK_SELECT ) {
cberror(topo->be_data, "unexpected return (%d) from query execution: %s", spi_result, sql->data);
@@ -2422,8 +2445,6 @@
bool isnull;
Datum dat;
LWT_ELEMID face_id;
- size_t hexewkb_size;
- SPIPlanPtr plan;
GSERIALIZED *pts;
Datum values[1];
Oid argtypes[1];
