[postgis-tickets] [PostGIS] #3665: Bugs in BRIN support
trac at osgeo.org
Tue Nov 1 10:12:58 PDT 2016
Reporter: rjuju | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.3.1
Component: postgis | Version: 2.3.x
Keywords: |
I found two bugs in the first BRIN support implementation:
- index corruption bug. It can happen if a geometry is inserted or
updated on a previously summarized range (new ranges are not automatically
summuraized), and isn't contained in the stored bounding box. This bug is
fixed in attached fix_brin_corruption.diff
Please note that this patch expose some required C function which were
previously only used for GiST indexes.
- memory leak. The leak is actually in an existing postgis function. I
believe it has been unnoticed until now because IFAICT it's only used in
GiST indexes, and postgres use a per-tuple MemoryContext for such indexes.
This bug is fixed in attached fix_brin_memory_leak.diff
These patches should be applied on 2.3 and trunk.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3665>
