[postgis-tickets] [PostGIS] #3667: Bug in geography ST_Segmentize
trac at osgeo.org
Tue Nov 8 23:02:56 PST 2016
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.3.1
Component: postgis | Version: 2.3.x
Keywords: |
There is still something wrong with ST_Segmentize geography as someone
noted on IRC:
From http://irclogs.geoapt.com/postgis/%23postgis.2016-11-08.log
15:42:57 skyrocker: E.g. SELECT
ST_AsText(ST_Segmentize(ST_GeographyFromText('LINESTRING(38.769917
10.780694, 38.769917 9.106194)'), 30000))
15:43:01 skyrocker: Results in LINESTRING(38.769917
10.780694,3.97245555092463e-308 5.68175492717434e-322,38.769917 9.106194)
15:43:12 skyrocker: Which is obviously not correct
15:45:18 skyrocker: Although after changing first coordinate
of first point in LINESTRING I get correct result (e.g. instead of
38.769917 put 38.769918)
15:46:50 skyrocker: And also for some werid reason swapping
order of points in LINESTRING also gives me correct result
The only thing I see special about this is that in cartesian it's
vertical.
Testing on
POSTGIS="2.3.0 r15146" GEOS="3.6.0-CAPI-1.10.0 r4265" PROJ="Rel. 4.9.1, 04
March 2015" GDAL="GDAL 2.1.1, released 2016/07/07" LIBXML="2.7.8"
LIBJSON="0.12" RASTER
The lengths are way off, so it's clearly wrong:
SELECT ST_Length(geog) As len_before, ST_Length(ST_Segmentize(geog,
30000)) As len_after
FROM (SELECT ST_GeographyFromText('LINESTRING(38.769917 10.780694,
38.769917 9.106194)') As geog) AS f;
len_before | len_after
185212.200983372 | 8865756.13359671
(1 row)
But as noted flipping the coordinates works
FROM (SELECT ST_GeographyFromText('LINESTRING(38.769917 9.106194,
38.769917 10.780694)') As geog) AS f;
185212.200983372 | 185212.200983372
(1 row)
This problem is new in 2.3.0 but not 2.2.2, so must be a continuation of
issue I complained about in #3539:
In POSTGIS="2.2.2 r14797" GEOS="3.5.0-CAPI-1.9.0 r4090" PROJ="Rel. 4.9.1,
04 March 2015" GDAL="GDAL 2.0.2, released 2016/01/26" LIBXML="2.7.8"
LIBJSON="0.12" RASTER the answers are right:
(1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3667>
