[postgis-tickets] [PostGIS] #3665: Bugs in BRIN support
trac at osgeo.org
Fri Nov 11 03:01:15 PST 2016
Reporter: rjuju | Owner: robe
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.3.1
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by rjuju):
I just attached brin_allfix_and_regtest-v1.diff​ (against svn-2.3), it's a
single patch containing the fixes for the 2 issues mentionned before and
the memory leak, add regression tests for all problematic tests, also
fixes some typo in documentation and add some more information about the
available operator classes and some advice about BRIN indexes with
geometries of mixed dimensions.
All the regression tests works after this patch, I didn't try to build
documentation though.
Tell me if you prefer to split in multiple patches, or if anything else is
needed. Thanks!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3665#comment:5>
