[postgis-tickets] [PostGIS] #3501: [raster] add raster constraint max extent exceeds array size limit
PostGIS trac at osgeo.org
Sun Nov 20 01:48:25 PST 2016
  Reporter:  hypostase  |      Owner:  dustymugs
      Type:  defect     |     Status:  reopened
  Priority:  medium     |  Milestone:  PostGIS 2.2.3
 Component:  raster     |    Version:  2.2.x
Resolution:             |   Keywords:
Changes (by robe):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 As noted in https://lists.osgeo.org/pipermail/postgis-
 users/2016-November/041720.html
 ST_Union did not fix and ST_MemUnion is too slow.  So will replace with
 ST_Extent after I do some benchmarks to make sure it doesn't adversely
 affect smaller tables.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3501#comment:7>
