[postgis-tickets] [PostGIS] #3670: Tolerance silently ignored in ST_RemoveRepeatedPoint for multipoint
trac at osgeo.org
Thu Nov 24 05:03:54 PST 2016
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.1
Component: postgis | Version: 2.3.x
Keywords: |
According to http://postgis.net/docs/ST_RemoveRepeatedPoints.html
ST_RemoveRepeatedPoints considers vertices within the tolerance of one
another as identical in case a tolerance is given, but this does NOT
happen for MULTIPOINT.
Also, I suggest to specify that for lines the distance between points is
only computed for *consecutive* points.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3670>
