[postgis-tickets] [PostGIS] #3439: [raster] inconsistent nodata values returned from multiband raster
trac at osgeo.org
Fri Nov 25 08:00:08 PST 2016
Reporter: gdrolet | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.2.4
Component: raster | Version: trunk
Resolution: | Keywords: raster2pgsql ST_Value
Comment (by robe):
Do you have a sample raster file in question here. Have you compared with
in database vs. out. Given the results, there is not enough for me to
tell if anything is wrong here?
In your first query they resturned all -9999 as expected.
In your overlay, you are looking at a tile that intersects your geometry
and are pulling out a value of the cell that intersects your point.
All that tells me is yes, at least one of the bands of each row should
return a non-nodata value, which it does (value of 0) which is not nodata.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3439#comment:5>
