[postgis-tickets] [PostGIS] #3660: Cannot import shapefile due to encoding problem
trac at osgeo.org
Fri Nov 25 08:00:36 PST 2016
Reporter: miguelluaces | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.3.1
Component: liblwgeom | Version: 2.3.x
Resolution: invalid | Keywords: shp2pgsql
Comment (by miguelluaces):
I should have written explicitly that the dataset is UTF-8, not LATIN1. If
you open the dbf file in LibreOffice using Latin1 as encoding you can see
that row number 3 is shown as
MuÃño Daniel o Ferreiro
instead of :
Muíño Daniel o Ferreiro
What should I do now? Compile it myself and set a breakpoint to see which
is the offending character? I would rather have the error messages
improved to show me which is the offending row so that I can try to fix
it.
And again, the same shapefile can be imported with shp2pgsql 2.1.7 with
the same commandline without errors.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3660#comment:2>
