[postgis-tickets] [PostGIS] #3650: Aggregate functions aren't marked as parallel safe (mark aggregates that don't use transition)
trac at osgeo.org
Sat Nov 26 10:07:25 PST 2016
Reporter: komzpa | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.1
Component: postgis | Version: 2.3.x
Resolution: | Keywords:
Comment (by robe):
This is annoying our uninstall script appears to require basetype in there
for aggregates.
basetype is considered deprecated syntax and has been for a while. As
noted in postgis thread, the safe stuff doesn't work if basetype is there.
https://www.postgresql.org/message-id/b1e247ca-23ad-1d24-cecc-
28600550f7bb at postgrespro.ru
presumably because basetype is arcane syntax they don't have work with
newer syntax.
https://www.postgresql.org/docs/9.2/static/sql-createaggregate.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3650#comment:4>
