[postgis-tickets] r15260 - Add build badges, trunk vs. branch release
Regina Obe
lr at pcorp.us
Sat Nov 26 13:49:51 PST 2016
Author: robe
Date: 2016-11-26 13:49:51 -0800 (Sat, 26 Nov 2016)
New Revision: 15260
branches/2.3/HOWTO_RELEASE
closes #3671 for PostGIS 2.3
Modified: branches/2.3/HOWTO_RELEASE
--- branches/2.3/HOWTO_RELEASE 2016-11-26 21:25:44 UTC (rev 15259)
+++ branches/2.3/HOWTO_RELEASE 2016-11-26 21:49:51 UTC (rev 15260)
@@ -65,11 +65,27 @@
- Update Version.config to drop the "dev" suffix
- Add the "dev" suffixed version in extensions/upgradeable_versions.mk
and ensure all the previous released minor versions are listed in it
+- Update the README.md to reflect new to be created buildbot badges
+ (this should only be needed for trunk release)
- Commit all changes
-- Tag branch:
+- If this is a minor or major release (no branch exists):
+ $ base=http://svn.osgeo.org/postgis/
+ $ rev=x.x
+ $ svn copy -m "Branch $rev" $base/trunk $base/branches/$rev
+ Go to: https://debbie.postgis.net and copy last branch version and make new job
+ a) Replace PostGIS_* string params with new version
+ b) Replace repository url with new branch repo url
+ c) Update the PostGIS_trunk by updating the PostGIS_* string params
+ d) create a new tagged branch job from latest tagged (and repeat a, b for this new tagged)
+ Go to: https://trac.osgeo.org/postgis/ edit the matrix to reflect new branch
+- Tag branch: (replace x.x and x.x.x with minor and micro version e.g 2.3, 2.3.1
- $ rev=x.x.0
- $ svn copy -m "Tagged release $rev" $base/trunk $base/tags/$rev
+ $ brev=x.x
+ $ rev=x.x.x
+ $ svn copy -m "Tagged release $rev" $base/branches/$brev $base/tags/$rev
- Run: sh make_dist.sh $rev (or use debbie for this)
- Build and test generated tarball (including extension upgrade)
- Copy tarball to web site and edit downloads page
