[postgis-tickets] [PostGIS] #2007: topogeo_addlinestring: error - geometry intersects edge
trac at osgeo.org
Mon Oct 3 01:24:16 PDT 2016
Reporter: amartin | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.8
Component: topology | Version: 2.0.x
Resolution: | Keywords: linestring, order
Comment (by amartin):
Updated complete test cas:
CREATE EXTENSION postgis;
CREATE EXTENSION postgis_topology;
SET search_path TO public, topology;
CREATE TABLE test_lines (id int4);
CREATE TABLE test_polygons (id int4);
SELECT CreateTopology('test_topo', 25830, 0.01);
SELECT AddTopoGeometryColumn('test_topo', 'public', 'test_lines', 'geom',
'LINE'); -- 1
SELECT AddTopoGeometryColumn('test_topo', 'public', 'test_polygons',
'geom', 'POLYGON'); -- 2
SELECT ToTopoGeom (st_geomfromtext('MULTIPOLYGON(((308602.91
4614696.3,308609.22 4614708.19,308619.74 4614723.97,308630.98
4614746.21,308636.76 4614764.04,308641.05 4614779.52,308652.12
4614791.86,308670.07 4614797.76,308686.51 4614795.59,308699.72
4614771.95,308710.27 4614752.2,308602.91 4614696.3)))', 25830),
'test_topo', 2, 0.01);
WITH
inp as (SELECT st_geomfromtext('MULTILINESTRING((308609.32
4614708.34,308609.22 4614708.19,308619.74 4614723.97,308630.98
4614771.95,308710.27 4614752.2),(308710.27 4614752.2,308609.32
4614708.34))', 25830) as g),
topo as (SELECT ToTopoGeom(g, 'test_topo', 1, 0.01) as t FROM inp)
SELECT st_astext(t) from topo ;
Could not reproduce defect on postgis 2.3.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2007#comment:13>
