[postgis-tickets] [PostGIS] #3652: Segmentation fault during operations on GEOMETRYCOLLECTION with MULTICURVE geometry inside
trac at osgeo.org
Thu Oct 6 06:15:25 PDT 2016
geometry inside
Reporter: alexeygl | Owner: pramsey
Type: defect | Status: reopened
Priority: high | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.2.x
Resolution: | Keywords: postgis GEOMETRYCOLLECTION MULTICURVE
Comment (by robe):
I thought it was just sfcgal tests failing, but on closer inspection,
getting failure on
my local PostgreSQL 9.5 run for these tests under my windows desktop.
What's really bugging me is that winnie actually passed the 9.5 64-bit on
this commit and yet we are supposed to be setup more or less the same.
I'm rerunning on debbie, she crashed on 9.5, but didn't show a regress on
her 9.6 run.
On spot check on failing tests,
the in_encodedpolyline test shows this
-linefromencodedpolyline_02|SRID=4326;LINESTRING(-120.234 38.5,-120.95
40.734,-126.453 43.252)
+linefromencodedpolyline_02|SRID=4326;LINESTRING(-1202.345 385,-1209.5
407.344,-1264.53 432.52)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3652#comment:7>
