[postgis-tickets] r15188 - Properly signal check errors, stopping on first error
Sandro Santilli
strk at kbt.io
Fri Oct 7 12:49:32 PDT 2016
Author: strk
Date: 2016-10-07 12:49:32 -0700 (Fri, 07 Oct 2016)
New Revision: 15188
trunk/utils/check_all_upgrades.sh
Modified: trunk/utils/check_all_upgrades.sh
--- trunk/utils/check_all_upgrades.sh 2016-10-07 19:30:52 UTC (rev 15187)
+++ trunk/utils/check_all_upgrades.sh 2016-10-07 19:49:32 UTC (rev 15188)
@@ -8,7 +8,6 @@
BUILDDIR=$PWD
EXTDIR=`pg_config --sharedir`/extension/
-RET=0
cd $EXTDIR
'ls' postgis--* | grep -v -- '--.*--' |
@@ -18,17 +17,8 @@
if test -e postgis--${UPGRADE_PATH}.sql; then
echo "Testing upgrade $UPGRADE_PATH"
export RUNTESTFLAGS="-v --extension --upgrade-path=${UPGRADE_PATH}"
- make -C ${BUILDDIR}/regress check
- ret=$?
- echo "UPGRADE TEST EXIT CODE: $ret"
- if test $ret -ne 0; then
- cat /tmp/pgis_reg/regress_log
- fi
- RET=$((RET+$ret))
- dropdb postgis_reg
+ make -C ${BUILDDIR}/regress check || exit 1
else
echo "Missing script for $UPGRADE_PATH upgrade" >&2
fi
done
-exit $RET
