[postgis-tickets] [PostGIS] #3653: ERROR: could not load library "/usr/lib/postgresql/9.5/lib/rtpostgis-2.2.so": libnetcdf.so.11: cannot map zero-fill pages
trac at osgeo.org
Mon Oct 10 02:55:55 PDT 2016
zero-fill pages
Reporter: reecefowell | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.1
Component: postgis | Version: 2.2.x
Resolution: | Keywords:
Comment (by reecefowell):
The Java is running on my Mac when running the tests, and the Postgresql
instance in a VirtualBox instance via Vagrant.
The vbox instance has only 1 GB of RAM as my project requires lots of
separate instances due to being a microservices based setup.
I changed it to 2GB and now all tests pass.
Thanks.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3653#comment:3>
