[postgis-tickets] r15208 - raster GUC - boot_postgis_gdal_enabled_drivers should use TopMemoryContext instead of CurrentMemoryContext
Regina Obe lr at pcorp.us
Sat Oct 15 14:16:04 PDT 2016
Author: robe
Date: 2016-10-15 14:16:04 -0700 (Sat, 15 Oct 2016)
New Revision: 15208
   trunk/raster/rt_pg/rtpostgis.c
References #3659  for trunk (PostGIS 2.4)
Modified: trunk/raster/rt_pg/rtpostgis.c
--- trunk/raster/rt_pg/rtpostgis.c	2016-10-12 19:12:12 UTC (rev 15207)
+++ trunk/raster/rt_pg/rtpostgis.c	2016-10-15 21:16:04 UTC (rev 15208)
@@ -132,6 +132,7 @@
 #include <postgres.h> /* for palloc */
 #include <fmgr.h> /* for PG_MODULE_MAGIC */
 #include "utils/guc.h"
+#include "utils/memutils.h"
 #include "../../postgis_config.h"
 #include "lwgeom_pg.h"
@@ -151,6 +152,9 @@
 /* Module load callback */
 void _PG_init(void);
+/* Module unload callback */
+void _PG_fini(void);
 #define RT_MSG_MAXLEN 256
@@ -244,6 +248,14 @@
 extern char *gdal_enabled_drivers;
 extern char enable_outdb_rasters;
+/*  Useful variables                                                */
+static char *env_postgis_gdal_enabled_drivers = NULL;
+static char *boot_postgis_gdal_enabled_drivers = NULL;
+static char *env_postgis_enable_outdb_rasters = NULL;
 /* postgis.gdal_datapath */
 static void
 rtpg_assignHookGDALDataPath(const char *newpath, void *extra) {
@@ -408,13 +420,16 @@
 void
 _PG_init(void) {
-	char *env_postgis_gdal_enabled_drivers = NULL;
-	char *boot_postgis_gdal_enabled_drivers = NULL;
-	char *env_postgis_enable_outdb_rasters = NULL;
 	bool boot_postgis_enable_outdb_rasters = false;
+	MemoryContext old_context;
+	 * Change to context for memory allocation calls like palloc() in the
+	 * extension initialization routine
+	old_context = MemoryContextSwitchTo(TopMemoryContext);
 	 use POSTGIS_GDAL_ENABLED_DRIVERS to set the bootValue
 	 of GUC postgis.gdal_enabled_drivers
@@ -543,8 +558,29 @@
-	/* free memory allocations */
+	/* Revert back to old context */
+	MemoryContextSwitchTo(old_context);
+void
+_PG_fini(void) {
+	/* Clean up */
+	pfree(env_postgis_gdal_enabled_drivers);
 	pfree(boot_postgis_gdal_enabled_drivers);
+	pfree(env_postgis_enable_outdb_rasters);
+	env_postgis_gdal_enabled_drivers = NULL;
+	boot_postgis_gdal_enabled_drivers = NULL;
+	env_postgis_enable_outdb_rasters = NULL;
