[postgis-tickets] r15212 - Add another path to search docbook xsl into
Sandro Santilli strk at kbt.io
Wed Oct 19 01:26:23 PDT 2016
Author: strk
Date: 2016-10-19 01:26:21 -0700 (Wed, 19 Oct 2016)
New Revision: 15212
   trunk/configure.ac
The added path is /usr/share/xml/docbook/stylesheet/docbook-xsl
which is the target of /usr/share/xml/docbook/stylesheet/nwalsh
being a symlink on Ubuntu 16.04
Modified: trunk/configure.ac
--- trunk/configure.ac	2016-10-18 04:19:28 UTC (rev 15211)
+++ trunk/configure.ac	2016-10-19 08:26:21 UTC (rev 15212)
@@ -229,6 +229,7 @@
 	dnl that matches from the following list
 	SEARCHPATH="
 		/usr/share/sgml/docbook/xsl-stylesheets
+		/usr/share/xml/docbook/stylesheet/docbook-xsl
 		/usr/share/sgml/docbook/stylesheet/xsl/nwalsh
 		/opt/local/share/xsl/docbook-xsl
