[postgis-tickets] [PostGIS] #3617: ST_ClusterDbScan sometimes returns NULL cluster numbers
trac at osgeo.org
Fri Sep 2 15:56:40 PDT 2016
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.3.0
Component: postgis | Version: trunk
Keywords: |
In trying to troubleshoot issue #3612, I came across this other oddity.
SELECT ST_ClusterDBScan(geom,0,2) OVER()
FROM (SELECT ST_Point(10*i,2) As geom
FROM generate_series(1,10) i ) AS f;
Returns all nulls:
st_clusterdbscan
NULL
NULL
NULL
NULL
NULL
NULL
NULL
NULL
NULL
NULL
(10 rows)
This is testing with:
POSTGIS="2.3.0dev r15043" GEOS="3.5.0-CAPI-1.9.0 r4090" PROJ="Rel. 4.9.1,
04 March 2015" GDAL="GDAL 2.1.0, released 2016/04/25" LIBXML="2.7.8"
LIBJSON="0.12" RASTER PostgreSQL 9.5.2, compiled by Visual C++ build 1800,
64-bit
as well as
POSTGIS="2.3.0dev r15050" GEOS="3.5.0-CAPI-1.9.0 r4090" SFCGAL="1.3.0"
PROJ="Rel. 4.9.1, 04 March 2015" GDAL="GDAL 2.1.0, released 2016/04/25"
LIBXML="2.7.8" LIBJSON="0.12" (core procs from "2.3.0dev r15044" need
upgrade) RASTER (raster procs from "2.3.0dev r15044" need upgrade) (sfcgal
procs from "2.3.0dev r15044" need upgrade) PostgreSQL 9.6beta4, compiled
by Visual C++ build 1800, 64-bit
and even testing under mingw
POSTGIS="2.3.0dev r15050" GEOS="3.5.0-CAPI-1.9.0 r4088" PROJ="Rel. 4.9.1,
LIBJSON="0.12" RASTER PostgreSQL 9.6beta4 on x86_64-w64-mingw32, compiled
by gcc.exe (x86_64-win32-seh-rev1, Built by MinGW-W64 project) 4.8.3,
64-bit
I'm going to go thru my real data examples I've tested before to see
what's up. I'm thinking this might have to do with recent changes in this
function since last I tested.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3617>
