[postgis-tickets] [PostGIS] #3604: pgcommon/Makefile.in orders CFLAGS incorrectly leading to wrong liblwgeom.h
trac at osgeo.org
Thu Sep 22 23:50:57 PDT 2016
Reporter: gdt | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.2.3
Component: build/upgrade/install | Version: trunk
Resolution: fixed | Keywords:
Changes (by robe):
* milestone: PostGIS 2.3.0 => PostGIS 2.2.3
Comment:
I was having this issue on FreeBSD because I think the postgis 2.3
liblwgeom I just installed was trying to be used by the 2.2 I was trying
to compile.
The error looked like this:
rtpg_geometry.c:105:42: error: too many arguments to function call,
expected 2, have 3
gser = gserialized_from_lwgeom(geom, 0, &gser_size);
/usr/local/include/liblwgeom.h:1957:1: note: 'gserialized_from_lwgeom'
declared here
extern GSERIALIZED* gserialized_from_lwgeom(LWGEOM *geom, size_t *size);
rtpg_geometry.c:184:42: error: too many arguments to function call,
expected 2, have 3
declared here
rtpg_geometry.c:326:81: error: too many arguments to function call,
expected 2, have 3
gser =
gserialized_from_lwgeom(lwpoly_as_lwgeom(geomval2[call_cntr].geom), 0,
&gser_size);
declared here
rtpg_geometry.c:628:59: error: too many arguments to function call,
expected 2, have 3
gser = gserialized_from_lwgeom(pix2[call_cntr].geom, 0,
&gser_size);
declared here
4 errors generated.
gmake[3]: *** [<builtin>: rtpg_geometry.o] Error 1
gmake[3]: Leaving directory
'/usr/home/robe/sources/postgis-2.2.2/raster/rt_pg'
gmake[2]: *** [Makefile:28: pglib] Error 2
gmake[2]: Leaving directory '/usr/home/robe/sources/postgis-2.2.2/raster'
gmake[1]: *** [GNUmakefile:16: all] Error 1
gmake[1]: Leaving directory '/usr/home/robe/sources/postgis-2.2.2'
*** Error code 2
This patch fixed the issue after I committed to 2.2, thanks Greg.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3604#comment:6>
