[postgis-tickets] [PostGIS] #3624: load_outdb related tests fail for 2.2.2 & 2.3.0-beta1on Debian unstable
trac at osgeo.org
Tue Sep 6 06:52:03 PDT 2016
Reporter: sebastic | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.3.0
Component: postgis | Version: 2.2.x
Keywords: |
It seems the `-pre.pl` & `-post.pl` scripts are no longer executed,
because the `load_outdb` tests report an error for the missing table:
ERROR: relation "raster_outdb_template" does not exist at character 22
To troubleshoot this issue I used the following patch:
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -638,7 +638,11 @@ sub eval_file
#$pl = <PL>;
#close(PL);
#eval($pl);
- do $file;
+ unless (my $return = do $file) {
+ warn "couldn't parse $file: $@" if $@;
+ warn "couldn't do $file: $!" unless defined $return;
+ warn "couldn't run $file" unless $return;
For the `load_outdb` related tests this reports:
PostgreSQL 9.5.4 on x86_64-pc-linux-gnu, compiled by gcc (Debian 6.1.1-11)
6.1.1 20160802, 64-bit
Postgis 2.3.0beta1 - r15063 - 2016-09-06 12:24:46
scripts 2.3.0beta1 r15063
raster scripts 2.3.0beta1 r15063
GEOS: 3.5.0-CAPI-1.9.0 r4084
PROJ: Rel. 4.9.3, 15 August 2016
GDAL: GDAL 2.1.1, released 2016/07/07
Running tests
check_gdal ..couldn't do load_outdb-pre.pl: No such file or directory at
../../../regress/run_test.pl line 643.
couldn't run load_outdb-pre.pl at ../../../regress/run_test.pl line 644.
failed (diff expected obtained: /tmp/pgis_reg/test_1_diff)
load_outdb ..couldn't do load_outdb-post.pl: No such file or directory at
couldn't run load_outdb-post.pl at ../../../regress/run_test.pl line 644.
failed (diff expected obtained: /tmp/pgis_reg/test_2_diff)
This seems to be caused by `.` being removed from `@INC` in perl to fix
[https://security-tracker.debia This seems to be caused by . being removed
from @INC in perl to fix CVE-2016-1238. n.org/tracker/CVE-2016-1238
CVE-2016-1238].
The `-pre.pl` & `-post.pl` scripts for `loader/` tests aren't executed
either, but those tests handle that gracefully when they cannot read the
expected files.
attachment:run_test-INC.patch adds `.` to `@INC` if it's not present,
which resolves this issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3624>
