[postgis-tickets] r15073 - load_outdb related tests fix for @INC change in perl
Regina Obe
lr at pcorp.us
Tue Sep 6 08:37:28 PDT 2016
Author: robe
Date: 2016-09-06 08:37:28 -0700 (Tue, 06 Sep 2016)
New Revision: 15073
branches/2.2/NEWS
branches/2.2/regress/run_test.pl
patch from Sebastiaan Couwenberg
closes #3624 for PostGIS 2.2
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS 2016-09-06 15:16:35 UTC (rev 15072)
+++ branches/2.2/NEWS 2016-09-06 15:37:28 UTC (rev 15073)
@@ -13,10 +13,13 @@
- #3579, Crash in LWGEOM2GEOS
- #3515, tiger_data not being backed up
- #3602, perl as found by configure is not used
- in tiger extension, postgis_sfcgal, address_standardizer
+ in tiger extension, postgis_sfcgal, address_standardizer
- #3607, Fix inconsistency with multilinestring in
ST_LocateBetweenElevations (Artur Zakirov)
- #3608, Fix crash passing -W UTF-8 to shp2pgsql (Matt Amos)
+ - #3624, [raster] load_outdb related tests fail
+ for 2.2.2 & 2.3.0-beta1 on Debian unstable
+ perl @INC fix (Sebastiaan Couwenberg)
PostGIS 2.2.2
@@ -38,8 +41,8 @@
platforms
- #3460, ST_ClusterWithin 'Tolerance not defined' error after upgrade
- #3490, Raster data restore issues, materialized views
- Scripts postgis_proc_set_search_path.sql, rtpostgis_proc_set_search_path.sql
- refere to http://postgis.net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore
+ Scripts postgis_proc_set_search_path.sql, rtpostgis_proc_set_search_path.sql
+ refere to http://postgis.net/docs/manual-2.2/RT_FAQ.html#faq_raster_data_not_restore
- #3426, failing POINT EMPTY tests on fun architectures
PostGIS 2.2.1
Modified: branches/2.2/regress/run_test.pl
--- branches/2.2/regress/run_test.pl 2016-09-06 15:16:35 UTC (rev 15072)
+++ branches/2.2/regress/run_test.pl 2016-09-06 15:37:28 UTC (rev 15073)
@@ -22,7 +22,14 @@
use Getopt::Long;
use strict;
+# Add . to @INC if removed for CVE-2016-1238
+BEGIN {
+ push @INC, "." if(!grep /^\.$/, @INC);
# Usage ./run_test.pl <testname> [<testname>]
