[postgis-tickets] [PostGIS] #3626: Is there a existing ticket for raster nodata larger than numeric(16, 10)?
PostGIS trac at osgeo.org
Tue Sep 6 08:54:51 PDT 2016
#3626: Is there a existing ticket for raster nodata larger than numeric(16,10)?
 Reporter:  pauldzy                   |      Owner:  dustymugs
     Type:  defect                    |     Status:  new
 Priority:  low                       |  Milestone:  PostGIS 2.3.0
Component:  raster                    |    Version:  2.2.x
 Keywords:  raster nodata constraint  |
 I have a variety of EPA grids using Int32 which arrive with a nodata value
 of -2147483647 or (after Esri processing) 2147483647.  Either way this
 fails in  _add_raster_constraint_nodata_values which requires the nodata
 value to fit into numeric(16,10).
 I don't think there is an existing ticket but I do see the relatively
 recent alterations to move scale from 16,10 to 25,10.  Is it possible to
 alter the nodata constraint creator to also use 25,10?
 Thanks,
 Paul
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3626>
