[postgis-tickets] [PostGIS] #3626: Is there a existing ticket for raster nodata larger than numeric(16, 10)?
trac at osgeo.org
Tue Sep 6 15:45:13 PDT 2016
#3626: Is there a existing ticket for raster nodata larger than numeric(16,10)?
Reporter: pauldzy | Owner: robe
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.3.0
Component: raster | Version: 2.2.x
Resolution: | Keywords: raster nodata constraint
Changes (by robe):
* owner: dustymugs => robe
Comment:
I don't see why not. Might be safe enough to back port to 2.2.3, but I'll
see. I forget if the raster_view makes some assumptions about it that may
require a drop / create, in which case, probably best to stick in 2.3.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3626#comment:1>
