[postgis-tickets] [PostGIS] #3626: Is there a existing ticket for raster nodata larger than numeric(16, 10)?
trac at osgeo.org
Sun Sep 18 16:28:45 PDT 2016
#3626: Is there a existing ticket for raster nodata larger than numeric(16,10)?
Reporter: pauldzy | Owner: robe
Type: defect | Status: closed
Priority: low | Milestone: PostGIS 2.3.0
Component: raster | Version: 2.2.x
Resolution: worksforme | Keywords: raster nodata constraint
Changes (by robe):
* status: new => closed
* resolution: => worksforme
Comment:
Paul,
Can you tell me which version of PostGIS you are running:
SELECT postgis_full_version();
I tested on PostGIS 2.2.2 as well as upcoming PostGIS 2.3.0rc1 and I'm not
seeing an issue.
To test I did this:
CREATE TABLE rt(rid integer, rast raster);
INSERT INTO rt(rid, rast)
SELECT 1, ST_AddBand(ST_MakeEmptyRaster(10, 10, 10, 10, 2, 2, 0, 0, 0), 1,
'64BF', -1, -2147483647);
SELECT AddRasterConstraints('rt', 'rast')
Which created a constraint as expected that looks like this:
ALTER TABLE rt
ADD CONSTRAINT enforce_nodata_values_rast CHECK
(_raster_constraint_nodata_values(rast) =
'{-2147483647.0000000000}'::numeric[]);
I also tried
CREATE TABLE rt2(rid integer, rast raster);
INSERT INTO rt2(rid, rast)
'64BF', -1, -2147483647.1234567890);
SELECT AddRasterConstraints('rt2', 'rast');
Which ends up creating a constraint
ALTER TABLE rt2
'{-2147483647.1234600000}'::numeric[]);
So though you losse some precision, works too.
And my raster_columns output looks like this:
SELECT r_table_name, nodata_values
FROM raster_columns;
r_table_name | nodata_values
rt | {-2147483647}
rt2 | {-2147483647.123456}
(1 row)
So both look fine to me. Is it possible that maybe not all your rasters
have the same no data value?
If you can give the error/notice you are seeing that would help.
I'm marking this as a worksforme to get it out of the way. Feel free to
reopen if you have an example with PostGIS 2.2.2+ that replicates the
issue or provide more info.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3626#comment:2>
