[postgis-tickets] [PostGIS] #3626: Is there a existing ticket for raster nodata larger than numeric(16, 10)?
trac at osgeo.org
Mon Sep 19 16:39:24 PDT 2016
#3626: Is there a existing ticket for raster nodata larger than numeric(16,10)?
Reporter: pauldzy | Owner: robe
Type: defect | Status: closed
Priority: low | Milestone: PostGIS 2.3.0
Component: raster | Version: 2.2.x
Resolution: worksforme | Keywords: raster nodata constraint
Comment (by pauldzy):
Hi robe,
Sorry I should have clearly marked this as 2.1.8 as I noticed it occurring
there. I dug around and you all corrected the issue here for 2.2.2.
https://github.com/postgis/postgis/commit/426be352b23973e96b00c6a738e3e6ce37d844d9
So the answer was there was an existing ticket! Apologies for the run-
around and thanks for checking this over.
Cheers,
Paul
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3626#comment:3>
