[postgis-tickets] r15075 - #3627, Encoded polyline functions ignore precision parameter
Daniel Baston
dbaston at gmail.com
Tue Sep 6 15:57:02 PDT 2016
Author: dbaston
Date: 2016-09-06 15:57:02 -0700 (Tue, 06 Sep 2016)
New Revision: 15075
branches/2.2/postgis/lwgeom_export.c
branches/2.2/postgis/lwgeom_in_encoded_polyline.c
branches/2.2/regress/in_encodedpolyline.sql
branches/2.2/regress/in_encodedpolyline_expected
branches/2.2/regress/out_geometry_expected
branches/2.2/regress/tickets.sql
branches/2.2/regress/tickets_expected
Modified: branches/2.2/postgis/lwgeom_export.c
--- branches/2.2/postgis/lwgeom_export.c 2016-09-06 22:44:47 UTC (rev 15074)
+++ branches/2.2/postgis/lwgeom_export.c 2016-09-06 22:57:02 UTC (rev 15075)
@@ -622,9 +622,9 @@
lwgeom = lwgeom_from_gserialized(geom);
PG_FREE_IF_COPY(geom, 0);
- if (PG_NARGS() >2 && !PG_ARGISNULL(2))
+ if (PG_NARGS() > 1 && !PG_ARGISNULL(1))
- precision = PG_GETARG_INT32(2);
+ precision = PG_GETARG_INT32(1);
if ( precision < 0 ) precision = 5;
Modified: branches/2.2/postgis/lwgeom_in_encoded_polyline.c
--- branches/2.2/postgis/lwgeom_in_encoded_polyline.c 2016-09-06 22:44:47 UTC (rev 15074)
+++ branches/2.2/postgis/lwgeom_in_encoded_polyline.c 2016-09-06 22:57:02 UTC (rev 15075)
@@ -35,9 +35,9 @@
encodedpolyline_input = PG_GETARG_TEXT_P(0);
encodedpolyline = text2cstring(encodedpolyline_input);
Modified: branches/2.2/regress/in_encodedpolyline.sql
--- branches/2.2/regress/in_encodedpolyline.sql 2016-09-06 22:44:47 UTC (rev 15074)
+++ branches/2.2/regress/in_encodedpolyline.sql 2016-09-06 22:57:02 UTC (rev 15075)
@@ -1,2 +1,2 @@
select 'linefromencodedpolyline_01',st_asewkt(st_linefromencodedpolyline('_p~iF~ps|U_ulLnnqC_mqNvxq`@'));
-select 'linefromencodedpolyline_02',st_asewkt(st_linefromencodedpolyline('_p~iFlhz|UuksL`wjCivjNvxq`@', 6));
+select 'linefromencodedpolyline_02',st_asewkt(st_linefromencodedpolyline('_izlhAj}oidF{}jgCrotj at chtxCn`{nI', 6));
Modified: branches/2.2/regress/in_encodedpolyline_expected
--- branches/2.2/regress/in_encodedpolyline_expected 2016-09-06 22:44:47 UTC (rev 15074)
+++ branches/2.2/regress/in_encodedpolyline_expected 2016-09-06 22:57:02 UTC (rev 15075)
@@ -1,2 +1,2 @@
linefromencodedpolyline_01|SRID=4326;LINESTRING(-120.2 38.5,-120.95 40.7,-126.453 43.252)
-linefromencodedpolyline_02|SRID=4326;LINESTRING(-120.23447 38.5,-120.95 40.73435,-126.453 43.252)
+linefromencodedpolyline_02|SRID=4326;LINESTRING(-120.234472 38.5,-120.95 40.734352,-126.453 43.252)
Modified: branches/2.2/regress/out_geometry_expected
--- branches/2.2/regress/out_geometry_expected 2016-09-06 22:44:47 UTC (rev 15074)
+++ branches/2.2/regress/out_geometry_expected 2016-09-06 22:57:02 UTC (rev 15075)
@@ -41,7 +41,7 @@
encoded_polyline_01|_p~iF~ps|U_ulLnnqC_mqNvxq`@
encoded_polyline_02|_p~iF~ps|U_ulLnnqC_mqNvxq`@
ERROR: Only SRID 4326 is supported.
-encoded_polyline_04|_p~iFlhz|UuksL`wjCivjNvxq`@
+encoded_polyline_04|_izlhAd}oidF{}jgCxotj at chtxCn`{nI
svg_empty_geom|
svg_option_01|M 1 -1 L 4 -4 5 -7
svg_option_02|M 1 -1 l 3 -3 1 -3
Modified: branches/2.2/regress/tickets.sql
--- branches/2.2/regress/tickets.sql 2016-09-06 22:44:47 UTC (rev 15074)
+++ branches/2.2/regress/tickets.sql 2016-09-06 22:57:02 UTC (rev 15075)
@@ -974,5 +974,12 @@
ST_Intersects(ST_Buffer(road.geom, sidewalk_offset + epsilon), sidewalks.geom) -- should be true
from road, sidewalks, params;
+-- #3583
+Select '#3583', ST_AsText(ST_GeomFromGeoJSON('{"type":"MultiPolygon", "coordinates":[[[139.10030364990232,35.16777444430609],5842.4224490305424]]}'));
+-- #3627
+SELECT '#3627a', ST_AsEncodedPolyline('SRID=4326;LINESTRING(-0.250691 49.283048,-0.250633 49.283376,-0.250502 49.283972,-0.251245 49.284028,-0.251938 49.284232,-0.251938 49.2842)', 6);
+SELECT '#3627b', ST_Equals(geom, ST_LineFromEncodedPolyline(ST_AsEncodedPolyline(geom, 7), 7)) FROM (VALUES ('SRID=4326;LINESTRING (0 0, 1 1)')) AS v (geom);
-- Clean up
DELETE FROM spatial_ref_sys;
Modified: branches/2.2/regress/tickets_expected
--- branches/2.2/regress/tickets_expected 2016-09-06 22:44:47 UTC (rev 15074)
+++ branches/2.2/regress/tickets_expected 2016-09-06 22:57:02 UTC (rev 15075)
@@ -293,3 +293,6 @@
#3470b|50
ERROR: Cannot set point values on EMPTY geometry, use ST_AddPoint to add points
#3579|f|t
+#3583|MULTIPOLYGON Z (EMPTY)
+#3627a|o}~~|AdshNoSsBgd at eGoBlm@wKhj@~@?
+#3627b|t
