[postgis-tickets] r15081 - Style only: remove trailing blankspaces
Sandro Santilli
strk at kbt.io
Wed Sep 7 11:30:38 PDT 2016
Author: strk
Date: 2016-09-07 11:30:38 -0700 (Wed, 07 Sep 2016)
New Revision: 15081
branches/2.2/regress/run_test.pl
Modified: branches/2.2/regress/run_test.pl
--- branches/2.2/regress/run_test.pl 2016-09-07 18:21:43 UTC (rev 15080)
+++ branches/2.2/regress/run_test.pl 2016-09-07 18:30:38 UTC (rev 15081)
@@ -33,7 +33,7 @@
# Usage ./run_test.pl <testname> [<testname>]
-# Create the spatial database 'postgis_reg' (or whatever $DB
+# Create the spatial database 'postgis_reg' (or whatever $DB
# is set to) if it doesn't already exist.
# Run the <testname>.sql script
@@ -74,7 +74,7 @@
GetOptions (
'verbose' => \$VERBOSE,
'clean' => \$OPT_CLEAN,
- 'nodrop' => \$OPT_NODROP,
+ 'nodrop' => \$OPT_NODROP,
'upgrade' => \$OPT_UPGRADE,
'upgrade-path=s' => \$OPT_UPGRADE_PATH,
'dumprestore' => \$OPT_DUMPRESTORE,
@@ -97,7 +97,7 @@
die "--upgrade-path is only supported with --extension"
- $OPT_UPGRADE = 1; # implied
+ $OPT_UPGRADE = 1; # implied
my @path = split ('--', $OPT_UPGRADE_PATH);
$OPT_UPGRADE_FROM = $path[0]
|| die "Malformed upgrade path, <from>--<to> expected, $OPT_UPGRADE_PATH given";
@@ -170,7 +170,7 @@
print "failed\n";
die "Unable to find $exec executable.\n";
if ( $OPT_WITH_RASTER )
@@ -393,13 +393,13 @@
start_test($TEST);
- # Check for a "-pre.pl" file in case there are setup commands
+ # Check for a "-pre.pl" file in case there are setup commands
eval_file("${TEST}-pre.pl");
# Check for a "-pre.sql" file in case there is setup SQL needed before
# the test can be run.
if ( -r "${TEST}-pre.sql" )
run_simple_sql("${TEST}-pre.sql");
show_progress();
@@ -441,18 +441,18 @@
print " ... but cleanup sql failed!";
- # Check for a "-post.pl" file in case there are teardown commands
+ # Check for a "-post.pl" file in case there are teardown commands
eval_file("${TEST}-post.pl");
# Uninstall postgis (serves as an uninstall test)
-# We only test uninstall if we've been asked to drop
+# We only test uninstall if we've been asked to drop
# and we did create
# and nobody requested raster or topology
# (until they have an uninstall script themself)
@@ -496,7 +496,7 @@
# Utility functions
-sub usage
+sub usage
die qq{
Usage: $0 [<options>] <testname> [<testname>]
@@ -539,7 +539,7 @@
print ".";
-# pass <msg>
+# pass <msg>
sub pass
my $msg = shift;
@@ -573,10 +573,10 @@
$FAIL++;
-# run_simple_sql
+# run_simple_sql
# Run an sql script and hide results unless it fails.
# SQL input file name is $1
@@ -584,7 +584,7 @@
my $sql = shift;
- if ( ! -r $sql )
+ if ( ! -r $sql )
fail("can't read $sql");
return 0;
@@ -596,18 +596,18 @@
#print($cmd);
my $rv = system($cmd);
# Check if psql errored out.
- if ( $rv != 0 )
+ if ( $rv != 0 )
fail("Unable to run sql script $sql", $tmpfile);
return 0;
# Check for ERROR lines
open FILE, "$tmpfile";
my @lines = <FILE>;
close FILE;
my @errors = grep(/^ERROR/, @lines);
if ( @errors > 0 )
fail("Errors while running sql script $sql", $tmpfile);
@@ -623,7 +623,7 @@
my $tblname = shift;
my $cmd = "psql -tXA -d $DB -c \"DROP TABLE IF EXISTS $tblname\" >> $REGRESS_LOG 2>&1";
- die "Could not run: $cmd\n" if $rv;
+ die "Could not run: $cmd\n" if $rv;
sub sql
@@ -649,7 +649,7 @@
-# run_simple_test
+# run_simple_test
# Run an sql script and compare results with the given expected output
# SQL input is ${TEST}.sql, expected output is {$TEST}_expected
@@ -664,7 +664,7 @@
return 0;
if ( ! $OPT_EXPECT )
if ( ! -r "$expected" )
@@ -727,10 +727,10 @@
$lines[$i] =~ s/^ROLLBACK/COMMIT/;
$lines[$i] =~ s/^psql.*(NOTICE|WARNING|ERROR):/\1:/g;
# Write out output file
open(FILE, ">$outfile");
- foreach my $l (@lines)
+ foreach my $l (@lines)
print FILE $l;
@@ -738,7 +738,7 @@
# Clean up interim stuff
#remove_tree($betmpdir);
if ( $OPT_EXPECT )
print " (expected)";
@@ -761,7 +761,7 @@
return 1;
return 1;
@@ -794,7 +794,7 @@
my ( $cmd, $rv );
my $outfile = "${TMPDIR}/loader.out";
my $errfile = "${TMPDIR}/loader.err";
# ON_ERROR_STOP is used by psql to return non-0 on an error
my $psql_opts = " --no-psqlrc --variable ON_ERROR_STOP=true";
@@ -822,7 +822,7 @@
return 0;
# Run the loader SQL script.
show_progress();
$cmd = "psql $psql_opts -f $outfile $DB > $errfile 2>&1";
@@ -864,13 +864,13 @@
my ($cmd, $rv);
my $errfile = "${TMPDIR}/dumper.err";
- if ( $run_always || -r $expected_shp_file )
+ if ( $run_always || -r $expected_shp_file )
show_progress();
$cmd = "${PGSQL2SHP} -f ${TMPDIR}/dumper $DB $tblname > $errfile 2>&1";
$rv = system($cmd);
if ( $rv )
fail("$description: dumping loaded table", $errfile);
@@ -878,11 +878,11 @@
# Compare with expected output if there is any.
if ( -r $expected_shp_file )
show_progress();
my $diff = diff($expected_shp_file, "$TMPDIR/dumper.shp");
if ( $diff )
@@ -921,7 +921,7 @@
my $expected_select_results_file = shift;
my $loader_options = shift;
my $run_always = shift;
my $psql_opts="--no-psqlrc --variable ON_ERROR_STOP=true";
@@ -929,20 +929,20 @@
- if ( $run_always || -r $expected_sql_file || -r $expected_select_results_file )
+ if ( $run_always || -r $expected_sql_file || -r $expected_select_results_file )
show_progress();
# Produce the output SQL file.
$cmd = "$RASTER2PGSQL $loader_options ${TEST}.tif $tblname > $outfile 2> $errfile";
$rv = system($cmd);
if ( $rv )
fail("$description: running raster2pgsql", $errfile);
return 0;
if ( -r $expected_sql_file )
show_progress();
@@ -952,7 +952,7 @@
fail(" $description: actual SQL does not match expected.", "$outfile");
return 0;
@@ -972,26 +972,26 @@
return 0 if ( ! $rv );
return 1;
-# run_loader_test
+# run_loader_test
# Load a shapefile with different methods, create a 'select *' SQL
-# test and run simple test with provided expected output.
+# test and run simple test with provided expected output.
# SHP input is ${TEST}.shp, expected output is {$TEST}.expected
-sub run_loader_test
+sub run_loader_test
# See if there is a custom command-line options file
my $opts_file = "${TEST}.opts";
my $custom_opts="";
if ( -r $opts_file )
open(FILE, $opts_file);
@@ -1059,22 +1059,22 @@
drop_table($tblname);
return 1;
-# run_dumper_test
+# run_dumper_test
# Run dumper and compare output with various expectances
# input is ${TEST}.dmp, where last line is considered to be the
# [table|query] argument for pgsql2shp and all the previous lines,
-# if any are
+# if any are
-sub run_dumper_test
+sub run_dumper_test
my $dump_file = "${TEST}.dmp";
@@ -1148,14 +1148,14 @@
-# run_raster_loader_test
+# run_raster_loader_test
sub run_raster_loader_test
my $custom_opts="";
@@ -1173,9 +1173,9 @@
return 0;
return 1;
@@ -1186,15 +1186,15 @@
sub count_db_objects
my $count = sql("WITH counts as (
- select count(*) from pg_type union all
- select count(*) from pg_proc union all
+ select count(*) from pg_type union all
+ select count(*) from pg_proc union all
select count(*) from pg_cast union all
select count(*) from pg_aggregate union all
select count(*) from pg_operator union all
select count(*) from pg_opclass union all
select count(*) from pg_namespace
where nspname NOT LIKE 'pg_%' union all
- select count(*) from pg_opfamily )
+ select count(*) from pg_opfamily )
select sum(count) from counts");
return $count;
@@ -1210,7 +1210,7 @@
return system($cmd);
-sub create_spatial
+sub create_spatial
my ($cmd, $rv);
print "Creating database '$DB' \n";
@@ -1223,7 +1223,7 @@
# Count database objects before installing anything
$OBJ_COUNT_PRE = count_db_objects();
- if ( $OPT_EXTENSIONS )
+ if ( $OPT_EXTENSIONS )
prepare_spatial_extensions();
@@ -1238,12 +1238,12 @@
my $file = shift;
my $strict = shift;
if ( $strict && ! -e $file )
- die "Unable to find $file\n";
+ die "Unable to find $file\n";
if ( -e $file )
@@ -1274,7 +1274,7 @@
$sql .= " VERSION '" . $OPT_UPGRADE_FROM . "'";
- print "Preparing db '${DB}' using: ${sql}\n";
+ print "Preparing db '${DB}' using: ${sql}\n";
my $cmd = "psql $psql_opts -c \"". $sql . "\" $DB >> $REGRESS_LOG 2>&1";
@@ -1323,14 +1323,14 @@
# Load postgis.sql into the database
load_sql_file("${STAGED_SCRIPTS_DIR}/postgis.sql", 1);
load_sql_file("${STAGED_SCRIPTS_DIR}/postgis_comments.sql", 0);
if ( $OPT_WITH_TOPO )
print "Loading Topology into '${DB}'\n";
load_sql_file("${STAGED_SCRIPTS_DIR}/topology.sql", 1);
load_sql_file("${STAGED_SCRIPTS_DIR}/topology_comments.sql", 0);
print "Loading Raster into '${DB}'\n";
@@ -1365,8 +1365,8 @@
die "$script not found\n";
- if ( $OPT_WITH_TOPO )
+ if ( $OPT_WITH_TOPO )
my $script = `ls ${STAGED_SCRIPTS_DIR}/topology_upgrade.sql`;
chomp($script);
@@ -1380,8 +1380,8 @@
- if ( $OPT_WITH_RASTER )
+ if ( $OPT_WITH_RASTER )
my $script = `ls ${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql`;
chomp($script);
@@ -1420,7 +1420,7 @@
die;
my $sql = "ALTER EXTENSION postgis_topology UPDATE TO '${nextver}'";
my $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
@@ -1430,7 +1430,7 @@
die;
return 1;
@@ -1459,9 +1459,9 @@
- my $ok = 1;
+ my $ok = 1;
my ($cmd, $rv);
# NOTE: "manually" dropping topology schema as EXTENSION does not
@@ -1478,7 +1478,7 @@
$rv = system($cmd);
$ok = 0 if $rv;
$cmd = "psql $psql_opts -c \"DROP EXTENSION postgis\" $DB >> $REGRESS_LOG 2>&1";
$rv = system($cmd);
die "\nError encountered dropping EXTENSION POSTGIS, see $REGRESS_LOG for details\n\n"
@@ -1492,9 +1492,9 @@
my $ok;
start_test("uninstall");
$ok = drop_spatial_extensions();
else
@@ -1502,11 +1502,11 @@
$ok = drop_spatial();
- if ( $ok )
+ if ( $ok )
show_progress(); # on to objects count
$OBJ_COUNT_POST = count_db_objects();
if ( $OBJ_COUNT_POST != $OBJ_COUNT_PRE )
fail("Object count pre-install ($OBJ_COUNT_PRE) != post-uninstall ($OBJ_COUNT_POST)");
@@ -1518,9 +1518,9 @@
return 1;
return 0;
# Dump and restore the database
sub dump_restore
