[postgis-tickets] r15080 - Do not require expecting DISCARD ALL
Sandro Santilli
strk at kbt.io
Wed Sep 7 11:21:43 PDT 2016
Author: strk
Date: 2016-09-07 11:21:43 -0700 (Wed, 07 Sep 2016)
New Revision: 15080
trunk/raster/test/regress/rt_createoverview_expected
trunk/regress/run_test.pl
.. actually it may be a good idea to run it always after each test ..
Modified: trunk/raster/test/regress/rt_createoverview_expected
--- trunk/raster/test/regress/rt_createoverview_expected 2016-09-07 18:21:35 UTC (rev 15079)
+++ trunk/raster/test/regress/rt_createoverview_expected 2016-09-07 18:21:43 UTC (rev 15080)
@@ -13,4 +13,3 @@
o_8_res1|r|res1|r|8
o_16_res1|r|res1|r|16
count|544|136|36|10|3
-DISCARD ALL
Modified: trunk/regress/run_test.pl
--- trunk/regress/run_test.pl 2016-09-07 18:21:35 UTC (rev 15079)
+++ trunk/regress/run_test.pl 2016-09-07 18:21:43 UTC (rev 15080)
@@ -713,7 +713,7 @@
@lines = grep(!/^(INSERT|DELETE|UPDATE|SELECT|COPY|DO)/, @lines);
@lines = grep(!/^(CONTEXT|RESET|ANALYZE)/, @lines);
@lines = grep(!/^(DROP|CREATE|ALTER|VACUUM)/, @lines);
- @lines = grep(!/^(LOG|SET|TRUNCATE)/, @lines);
+ @lines = grep(!/^(LOG|SET|TRUNCATE|DISCARD)/, @lines);
@lines = grep(!/^LINE \d/, @lines);
@lines = grep(!/^\s+$/, @lines);
