[postgis-tickets] r15099 - Remove trailing spaces
Sandro Santilli
strk at kbt.io
Mon Sep 12 09:17:26 PDT 2016
Author: strk
Date: 2016-09-12 09:17:26 -0700 (Mon, 12 Sep 2016)
New Revision: 15099
trunk/raster/rt_pg/Makefile.in
Modified: trunk/raster/rt_pg/Makefile.in
--- trunk/raster/rt_pg/Makefile.in 2016-09-12 16:01:16 UTC (rev 15098)
+++ trunk/raster/rt_pg/Makefile.in 2016-09-12 16:17:26 UTC (rev 15099)
@@ -54,7 +54,7 @@
# Note: we specify liblwgeom.a directly in SHLIB_LINK rather than using
# -L... -l options to prevent issues with some platforms trying to link
# to an existing liblwgeom.so in the PostgreSQL $libdir supplied by an
-# older version of PostGIS, rather than with the static liblwgeom.a
+# older version of PostGIS, rather than with the static liblwgeom.a
# supplied with newer versions of PostGIS
LIBLWGEOM_LDFLAGS=../../liblwgeom/.libs/liblwgeom.a
@@ -67,13 +67,13 @@
override CFLAGS := $(LIBLWGEOM_CFLAGS) $(CFLAGS)
PG_CPPFLAGS+= @CPPFLAGS@ $(LIBGDAL_CFLAGS) $(LIBPGCOMMON_CFLAGS) $(LIBPROJ_CFLAGS) -I../rt_core
-SHLIB_LINK_F = ../rt_core/librtcore.a $(LIBLWGEOM_LDFLAGS) $(LIBPGCOMMON_LDFLAGS) $(LIBGDAL_LDFLAGS) @SHLIB_LINK@
+SHLIB_LINK_F = ../rt_core/librtcore.a $(LIBLWGEOM_LDFLAGS) $(LIBPGCOMMON_LDFLAGS) $(LIBGDAL_LDFLAGS) @SHLIB_LINK@
# Extra files to remove during 'make clean'
EXTRA_CLEAN=$(SQL_OBJS) $(DATA_built) rtpostgis_upgrade.sql.in
# PGXS information
-PG_CONFIG = @PG_CONFIG@
+PG_CONFIG = @PG_CONFIG@
PGXS := @PGXS@
# NO_TEMP_INSTALL is a workaround for a 9.5dev bug. See:
# http://www.postgresql.org/message-id/CAB7nPqTsR5o3g-fBi6jbsVdhfPiLFWQ_0cGU5=94Rv_8W3qvFA@mail.gmail.com
@@ -103,7 +103,7 @@
%.sql: %.sql.in
$(SQLPP) -I../../postgis/ -I../../ $< | grep -v '^#' | \
$(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/rtpostgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g;s'@extschema@\.''g" > $@
rtpostgis_for_extension.sql: rtpostgis.sql.in
$(PERL) -lpe "s'MODULE_PATHNAME'\$$libdir/rtpostgis- at POSTGIS_MAJOR_VERSION@. at POSTGIS_MINOR_VERSION@'g" > $@
@@ -128,10 +128,10 @@
#this is redundant but trying to fold in with the other just hangs
rtpostgis_upgrade.sql.in: rtpostgis.sql ../../utils/postgis_proc_upgrade.pl
$(PERL) ../../utils/postgis_proc_upgrade.pl $< UNUSED > $@
rtpostgis_upgrade_for_extension.sql.in: rtpostgis_for_extension.sql ../../utils/postgis_proc_upgrade.pl
rtpostgis_proc_set_search_path.sql: rtpostgis.sql ../../utils/postgis_proc_set_search_path.pl
$(PERL) ../../utils/postgis_proc_set_search_path.pl $< UNUSED > $@
@@ -139,14 +139,14 @@
echo 'BEGIN;' > $@
cat $^ | sed -e 's/^BEGIN;$$//' -e 's/^COMMIT;$$//' >> $@
echo 'COMMIT;' >> $@
#this keeps the @extschema at . in place since extension machinery will replace during install
rtpostgis_upgrade_for_extension.sql: rtpostgis_upgrade_cleanup.sql rtpostgis_upgrade_for_extension.sql.in rtpostgis_drop.sql
echo 'BEGIN;' > $@
-uninstall_rtpostgis.sql: rtpostgis.sql ../../utils/create_undef.pl
+uninstall_rtpostgis.sql: rtpostgis.sql ../../utils/create_undef.pl
$(PERL) ../../utils/create_undef.pl $< $(POSTGIS_PGSQL_VERSION) > $@
distclean: clean
