[postgis-tickets] [PostGIS] #3630: Both debbie and winnie are failing on sfcgal tickets
PostGIS trac at osgeo.org
Mon Sep 12 10:06:09 PDT 2016
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 2.3.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
  sfcgal/tickets .. failed (diff expected obtained:
 /projects/postgis/tmp/2.3.0rc1dev_pg9.6_geos3.5.0_gdal2.1.1w64/test_123_diff)
 --- sfcgal/tickets_expected     2016-09-12 12:02:22 -0400
 /projects/postgis/tmp/2.3.0rc1dev_pg9.6_geos3.5.0_gdal2.1.1w64/test_123_out
 2016-09-12 12:05:53 -0400
 @@ -197,7 +197,7 @@
  #852.2|1|t|t
  #852.2|2|t|t
  #1489|MULTIPOINT EMPTY|0|MULTILINESTRING EMPTY|0|MULTIPOLYGON
 EMPTY|0|GEOMETRYCOLLECTION EMPTY|0
 -ERROR:  AddToPROJ4SRSCache: could not parse proj4 string ''
 +ERROR:  AddToPROJ4SRSCache: could not parse proj4 string ''
  #1038|
  #1042|2
  #1170|90
 @@ -208,7 +208,7 @@
  #1580.1|Point[S]
  ERROR:  transform: couldn't project point (180 90 0): tolerance condition
 error (-20)
  #1580.3|Point[S]
 -#1596.1|public.road_pg.roads_geom SRID:3395 TYPE:POINT DIMS:2
 +#1596.1|public.road_pg.roads_geom SRID:3395 TYPE:POINT DIMS:2
  ERROR:  invalid SRID: 330000 not found in spatial_ref_sys
  #1596.3|3395
  ERROR:  invalid SRID: 999000 not found in spatial_ref_sys
 Since commit  r15098
 Looks like just a linefeed issue probably.  What's odd is my commit should
 have broken things and strk's fixed, but seems to be other way around.
 Mine didn't trigger a failure but his did.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3630>
