[postgis-tickets] r15102 - Fix DEBUG build of topology
Sandro Santilli
strk at kbt.io
Tue Sep 13 01:38:49 PDT 2016
Author: strk
Date: 2016-09-13 01:38:49 -0700 (Tue, 13 Sep 2016)
New Revision: 15102
trunk/topology/sql/populate.sql.in
Modified: trunk/topology/sql/populate.sql.in
--- trunk/topology/sql/populate.sql.in 2016-09-12 18:00:44 UTC (rev 15101)
+++ trunk/topology/sql/populate.sql.in 2016-09-13 08:38:49 UTC (rev 15102)
@@ -437,7 +437,9 @@
RAISE EXCEPTION 'Face geometry must be a polygon';
END IF;
- for rrec IN SELECT (ST_DumpRings(ST_ForceRHR(apoly))).geom
+ for rrec IN SELECT (d).* FROM (
+ SELECT ST_DumpRings(ST_ForceRHR(apoly)) d
+ ) foo
LOOP -- {
-- Find all bounds edges, forcing right-hand-rule
