[postgis-tickets] r15103 - Fix DEBUG build of topology
Sandro Santilli
strk at kbt.io
Tue Sep 13 01:39:11 PDT 2016
Author: strk
Date: 2016-09-13 01:39:11 -0700 (Tue, 13 Sep 2016)
New Revision: 15103
branches/2.2/topology/sql/populate.sql.in
Modified: branches/2.2/topology/sql/populate.sql.in
--- branches/2.2/topology/sql/populate.sql.in 2016-09-13 08:38:49 UTC (rev 15102)
+++ branches/2.2/topology/sql/populate.sql.in 2016-09-13 08:39:11 UTC (rev 15103)
@@ -437,7 +437,9 @@
RAISE EXCEPTION 'Face geometry must be a polygon';
END IF;
- for rrec IN SELECT (ST_DumpRings(ST_ForceRHR(apoly))).geom
+ for rrec IN SELECT (d).* FROM (
+ SELECT ST_DumpRings(ST_ForceRHR(apoly)) d
+ ) foo
LOOP -- {
-- Find all bounds edges, forcing right-hand-rule
