[postgis-tickets] [PostGIS] #2841: ST_MinimumBoundingCircle and ST_ConcaveHull not covering original
trac at osgeo.org
Wed Sep 14 09:04:48 PDT 2016
Reporter: robe | Owner: robe
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.2.3
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by dbaston):
In [changeset:"15109" 15109]:
#!CommitTicketReference repository="" revision="15109"
New method to approximate minimum bounding circle polygon without using
ST_Buffer. (References #2841, #3620)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2841#comment:15>
