[postgis-tickets] [PostGIS] #3634: raster crashes in regress under windows on winnie runs
trac at osgeo.org
Thu Sep 15 06:19:25 PDT 2016
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.1.9
Component: buildbots | Version: 2.1.x
Keywords: windows |
I've been getting this for some time and have been ignoring.
On winnie, the 9.3 failry frequently crashes in 2.1. What's odd is it
doesn't in 2.2 and trunk releases. I upgraded 2.1 to use GDAL 2.1.1 like
others and that didn't help.
permitted_gdal_drivers .. failed (diff expected obtained:
/projects/postgis/tmp/2.1.9dev_pg9.3_geos3.5.0_gdal2.1.1w64/test_68_diff)
--- permitted_gdal_drivers_expected 2014-05-04 12:24:55 -0400
/projects/postgis/tmp/2.1.9dev_pg9.3_geos3.5.0_gdal2.1.1w64/test_68_out
2016-09-15 03:41:38 -0400
@@ -1,10 +1,6 @@
DO
4326
-ERROR: RASTER_fromGDALRaster: Could not open bytea with GDAL. Check that
the bytea is of a GDAL supported format
-ERROR: rt_raster_load_offline_data: Access to offline bands disabled
-4326
-4326
-4326
+server closed the connection unexpectedly
+ This probably means the server terminated abnormally
+ before or while processing the request.
+connection to server was lost
tickets .. failed (diff expected obtained:
/projects/postgis/tmp/2.1.9dev_pg9.3_geos3.5.0_gdal2.1.1w64/test_69_diff)
--- tickets_expected 2015-05-02 16:49:13 -0400
/projects/postgis/tmp/2.1.9dev_pg9.3_geos3.5.0_gdal2.1.1w64/test_69_out
@@ -1,14 +1 @@
-#1485|0
-#2532.1|
-#2532.2|
-NOTICE: Raster has default geotransform. Adjusting metadata for use of
GDAL Warp API
-#2911|0|0|5|5|2|-2|0|0|0|1
-t
-test_raster_scale_regular|rast||1
-ERROR: new row for relation "test_raster_scale_regular" violates check
constraint "enforce_scaley_rast"
-t
-test_raster_scale_big|rast|-12345678901234|1
-ERROR: new row for relation "test_raster_scale_big" violates check
constraint "enforce_scalex_rast"
-t
-test_raster_scale_small|rast||1
-ERROR: new row for relation "test_raster_scale_small" violates check
+psql: FATAL: the database system is in recovery mode
loader/Basic ... failed ( test: running raster2pgsql output:
/projects/postgis/tmp/2.1.9dev_pg9.3_geos3.5.0_gdal2.1.1w64/loader.err)
loader/BasicCopy ... failed ( test: running raster2pgsql output:
loader/BasicFilename ... failed ( test: running raster2pgsql output:
clean .. failed (diff expected obtained:
/projects/postgis/tmp/2.1.9dev_pg9.3_geos3.5.0_gdal2.1.1w64/test_73_diff)
--- clean_expected 2013-11-27 11:24:48 -0500
/projects/postgis/tmp/2.1.9dev_pg9.3_geos3.5.0_gdal2.1.1w64/test_73_out
@@ -0,0 +1 @@
uninstall . /projects/postgis/branches/2.1/regress/00-regress-
install/share/contrib/postgis/uninstall_rtpostgis.sql
Error encountered loading /projects/postgis/branches/2.1/regress/00
-regress-install/share/contrib/postgis/uninstall_rtpostgis.sql, see
/projects/postgis/tmp/2.1.9dev_pg9.3_geos3.5.0_gdal2.1.1w64/regress_log
for details
I haven't ruled out it's a bot issue since I haven't tested locally yet.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3634>
