[postgis-tickets] r15118 - doc corrections from ruvyn for PostGIS 2.3
Regina Obe lr at pcorp.us
Sun Sep 18 21:54:41 PDT 2016
Author: robe
Date: 2016-09-18 21:54:41 -0700 (Sun, 18 Sep 2016)
New Revision: 15118
   trunk/doc/faq_raster.xml
   trunk/doc/reference_constructor.xml
   trunk/doc/reference_raster.xml
references #3581
references #3580
references #3586
references #3575
Modified: trunk/doc/faq_raster.xml
--- trunk/doc/faq_raster.xml	2016-09-19 04:00:29 UTC (rev 15117)
+++ trunk/doc/faq_raster.xml	2016-09-19 04:54:41 UTC (rev 15118)
@@ -248,7 +248,7 @@
       </question>
       <answer>
-        <para>The function is not unique error happens if one of your arguments is a textual representation of a geometry instead of a geometry.  In these cases, PostgreSQL marks the textual representation as an unknown type, which means it can fall into the st_intersects(raster, geometry) or st_intersects(raster,raster) thus resulting in a non-unique case since both functions can in theory support your request.  To prevent this, you need to cast the geometry to a geometry.</para>
+        <para>The function is not unique error happens if one of your arguments is a textual representation of a geometry instead of a geometry.  In these cases, PostgreSQL marks the textual representation as an unknown type, which means it can fall into the st_intersects(raster, geometry) or st_intersects(raster,raster) thus resulting in a non-unique case since both functions can in theory support your request.  To prevent this, you need to cast the textual representation of the geometry to a geometry.</para>
         <para>For example if your code looks like this:</para>
         <programlisting>SELECT rast
  FROM my_raster
Modified: trunk/doc/reference_constructor.xml
--- trunk/doc/reference_constructor.xml	2016-09-19 04:00:29 UTC (rev 15117)
+++ trunk/doc/reference_constructor.xml	2016-09-19 04:54:41 UTC (rev 15118)
@@ -425,7 +425,7 @@
 \\312Q\\300\\366{b\\235*!E@\\225|\\354.P\\312Q
 \\300p\\231\\323e1!E@');</programlisting>
-		<note><para>In PostgreSQL 9.1+ - standard_conforming_strings is set to on by default, where as in past versions it was set to on.  You can change defaults as needed
+		<note><para>In PostgreSQL 9.1+ - standard_conforming_strings is set to on by default, where as in past versions it was set to off.  You can change defaults as needed
 		    for a single query or at the database or server level.  Below is how you would do it with standard_conforming_strings = on.  In this case we escape the ' with standard ansi ',
 		    but slashes are not escaped</para></note>
 	<programlisting>
Modified: trunk/doc/reference_raster.xml
--- trunk/doc/reference_raster.xml	2016-09-19 04:00:29 UTC (rev 15117)
+++ trunk/doc/reference_raster.xml	2016-09-19 04:54:41 UTC (rev 15118)
@@ -6423,13 +6423,18 @@
 					<title>Examples</title>
 					<para>A simple example reskewing a raster from a skew of 0.0 to a skew of 0.0015.</para>
-					<programlisting>-- the original raster pixel size
-SELECT ST_Rotation(ST_AddBand(ST_MakeEmptyRaster(100, 100, 0, 0, 0.001, -0.001, 0, 0, 4269), '8BUI'::text, 1, 0))
+					<programlisting>-- the original raster non-rotated
+SELECT ST_Rotation(ST_AddBand(ST_MakeEmptyRaster(100, 100, 0, 0, 0.001, -0.001, 0, 0, 4269), '8BUI'::text, 1, 0));
--- the rescaled raster raster pixel size
-SELECT ST_Rotation(ST_Reskew(ST_AddBand(ST_MakeEmptyRaster(100, 100, 0, 0, 0.001, -0.001, 0, 0, 4269), '8BUI'::text, 1, 0), 0.0015))
-                    </programlisting>
+-- result
+0
+-- the reskewed raster raster rotation
+SELECT ST_Rotation(ST_Reskew(ST_AddBand(ST_MakeEmptyRaster(100, 100, 0, 0, 0.001, -0.001, 0, 0, 4269), '8BUI'::text, 1, 0), 0.0015));
+-- result
+-0.982793723247329</programlisting>
 			</refsection>
 			<refsection>
@@ -6506,12 +6511,16 @@
 					<para>A simple example snapping a raster to a slightly different grid.</para>
-SELECT ST_UpperLeftX(ST_AddBand(ST_MakeEmptyRaster(10, 10, 0, 0, 0.001, -0.001, 0, 0, 4269), '8BUI'::text, 1, 0))
+					<programlisting>-- the original raster upper left X
+SELECT ST_UpperLeftX(ST_AddBand(ST_MakeEmptyRaster(10, 10, 0, 0, 0.001, -0.001, 0, 0, 4269), '8BUI'::text, 1, 0));
+-- result
+0
+-- the upper left of raster after snapping
+SELECT ST_UpperLeftX(ST_SnapToGrid(ST_AddBand(ST_MakeEmptyRaster(10, 10, 0, 0, 0.001, -0.001, 0, 0, 4269), '8BUI'::text, 1, 0), 0.0002, 0.0002));
-SELECT ST_UpperLeftX(ST_SnapToGrid(ST_AddBand(ST_MakeEmptyRaster(10, 10, 0, 0, 0.001, -0.001, 0, 0, 4269), '8BUI'::text, 1, 0), 0.0002, 0.0002))
-                    </programlisting>
+--result
+-0.0008</programlisting>
 			</refsection>
