[postgis-tickets] [PostGIS] #2985: server crash when analyzing small tables
PostGIS trac at osgeo.org
Thu Sep 22 22:23:38 PDT 2016
  Reporter:  nkiraly   |      Owner:  pramsey
      Type:  defect    |     Status:  reopened
  Priority:  critical  |  Milestone:  PostGIS 2.2.3
 Component:  postgis   |    Version:  2.2.x
Resolution:            |   Keywords:  analyze server crash freebsd
Comment (by robe):
 ofca, how did you ever get PostGIS 2.2.2 installed?  Did you have to hack
 it.
 I just tried compiling from PostGIS 2.2.2 tarball and get this:
 wget http://download.osgeo.org/postgis/source/postgis-2.2.2.tar.gz
 tar -xvzf postgis-2.2.2.tar.gz
 cd postgis-2.2.2
 ./configure
 make
 rtpg_geometry.c:105:42: error: too many arguments to function call,
 expected 2, have 3
         gser = gserialized_from_lwgeom(geom, 0, &gser_size);
 /usr/local/include/liblwgeom.h:1957:1: note: 'gserialized_from_lwgeom'
 declared here
 extern GSERIALIZED* gserialized_from_lwgeom(LWGEOM *geom, size_t *size);
 rtpg_geometry.c:184:42: error: too many arguments to function call,
 expected 2, have 3
 declared here
 rtpg_geometry.c:326:81: error: too many arguments to function call,
 expected 2, have 3
                 gser =
 gserialized_from_lwgeom(lwpoly_as_lwgeom(geomval2[call_cntr].geom), 0,
 &gser_size);
 declared here
 rtpg_geometry.c:628:59: error: too many arguments to function call,
 expected 2, have 3
                 gser = gserialized_from_lwgeom(pix2[call_cntr].geom, 0,
 &gser_size);
 declared here
 4 errors generated.
 gmake[3]: *** [<builtin>: rtpg_geometry.o] Error 1
 gmake[3]: Leaving directory
 '/usr/home/robe/sources/postgis-2.2.2/raster/rt_pg'
 gmake[2]: *** [Makefile:28: pglib] Error 2
 gmake[2]: Leaving directory '/usr/home/robe/sources/postgis-2.2.2/raster'
 gmake[1]: *** [GNUmakefile:16: all] Error 1
 gmake[1]: Leaving directory '/usr/home/robe/sources/postgis-2.2.2'
 *** Error code 2
 Stop.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2985#comment:29>
