[postgis-tickets] [PostGIS] #3639: ../../utils/create_spatial_ref_sys_config_dump.pl: not found on FreeBSD (was: Can't build from tar ball on FreeBSD)
PostGIS trac at osgeo.org
Thu Sep 22 22:50:31 PDT 2016
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  high     |  Milestone:  PostGIS 2.3.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:  freebsd
Comment (by robe):
 okeedoke, after doing:
 pkg install libxslt
 then proceeding to compile from svn, I get the same error.
 gmake[2]: Leaving directory '/usr/home/robe/sources/postgis-2.3/doc'
 ---- Making all in extensions
 gmake[2]: Entering directory
 '/usr/home/robe/sources/postgis-2.3/extensions'
 for DIR in postgis  postgis_tiger_geocoder  postgis_topology
 address_standardizer; do \
         echo "---- Making all in ${DIR}"; \
         /usr/local/bin/gmake -C "${DIR}" all || exit 1; \
 done
 ---- Making all in postgis
 gmake[3]: Entering directory
 '/usr/home/robe/sources/postgis-2.3/extensions/postgis'
 mkdir -p sql_bits/
 /usr/local/bin/perl -pe 's/BEGIN\;//g ; s/COMMIT\;//g'
 ../../postgis/postgis_for_extension.sql > sql_bits/postgis.sql
 cp ../../doc/postgis_comments.sql sql_bits/postgis_comments.sql
 mkdir -p sql_bits
 ../../raster/rt_pg/rtpostgis_for_extension.sql > sql_bits/rtpostgis.sql
 ../../spatial_ref_sys.sql > sql_bits/spatial_ref_sys_config_dump.sql
 gmake[3]: *** [Makefile:80: sql_bits/spatial_ref_sys_config_dump.sql]
 Error 127
 gmake[3]: *** Deleting file 'sql_bits/spatial_ref_sys_config_dump.sql'
 gmake[3]: Leaving directory
 gmake[2]: *** [Makefile:26: all] Error 1
 gmake[1]: *** [GNUmakefile:16: all] Error 1
 gmake[1]: Leaving directory '/usr/home/robe/sources/postgis-2.3'
 *** Error code 2
  So before it's just my svn install wasn't trying to build extension since
 comments was missing.
 so it must be the ../ thing.  Anyone on FreeBSD can tell me what I'm doing
 wrong.  Haven't had this issue compiling on windows under mingw.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3639#comment:2>
