[postgis-tickets] [PostGIS] #2985: server crash when analyzing small tables
trac at osgeo.org
Fri Sep 23 12:38:14 PDT 2016
Reporter: nkiraly | Owner: pramsey
Type: defect | Status: reopened
Priority: critical | Milestone: PostGIS 2.2.3
Component: postgis | Version: 2.2.x
Resolution: | Keywords: analyze server crash freebsd
Comment (by robe):
I downgraded to 9.3 and installed PostGIS 2.1.7 from ports and it crashes.
I also tried by 9.5 compiling my own PostGIS 2.2.2 (after I applied Greg's
patch) and it did not crash.
If I compiled PostGIS 2.2 from svn branch, it doesn't crash (even on the
9.3 I got from ports).
So I'm not sure if its something about the way FreeBSD ports is compiling
PostGIS or patched it so it would work or perhaps Greg's liblwgeom patched
fixed things and they were compiling against an incompatible liblwgeom.h
header.
You said you got 2.2.2 from ports -- what's the pkg install for that.
If I do:
pkg install postgis
I just get the 2.1.7 which only works with 9.3. I thought I had done this
before, but perhaps not. Not sure where my production got their 2.2.2
since I didn't install it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2985#comment:32>
